I've got some weird gradients going on with bidir, note the part on the top of the image...
bidir:
pathOCL:
blender file:
bidir vs pathocl Shading
- FarbigeWelt
- Contact:
Re: bidir vs pathocl Shading
I have no access to my PC at the moment and cannot look at the object. This is why I ask a few questions.
Is the object smooth or flat shaded?
Do you see a gradient in solid openGL preview in viewport too?
If yes you can avoid this. Extrude top surface in edit mode. Move extruded surface a short way upwards (z-axis) just so that you can distinct vertices in top corners. The openGL shading should be uniform now. The render will be too.
MacBook Air with M1
MacBook Air with M1
Thanks, I'm aware how shading works. It would be kinda weird if I didn't by now it would also look the same in OCL rendering as in bidir if that was the case...FarbigeWelt wrote: ↑Tue Aug 06, 2019 7:06 amI have no access to my PC at the moment and cannot look at the object. This is why I ask a few questions.
It's a simple flat plane, tried reseting normals, smoothing, flattening normals, reversing normals... and idk what else..
I'm aware of this problem but I have yet to investigate the source, it must be something in MIS weights.
Is there some ETA on this? I need caustics(POOL) for my next project that means only bidir+metro+LOT of rendertime...
For me that means either bidir+metro but there is this shading issue, or wait until lighttracing gets vertex merging, not sure which will come sooner and my only other option is fake caustics+cycles and I really don't want to go back to cycles now that 2.8 will have luxcore addon...
- FarbigeWelt
- Contact:
Actually I did not expect anything else from someone with experienced skills. But even close to perfection people forget sometimes the simplest things.lacilaci wrote: ↑Tue Aug 06, 2019 7:12 am
However, until yesterday I thought to know how Blender deals with surfaces and shading. What was that of an error! I have to post my latest observations this evening maybe someone of the forum has the explanations. There must be some hidden parameters of a triangle‘s surface which are independent on vertices and surface normal and these parameters are responsible for different smooth shading tones.
MacBook Air with M1
MacBook Air with M1
I have a feeling that you might have ran into a problem of custom normals in blender, where these are often not exported to luxcore and cause a LOT of trouble especially when you use CAD models or create custom breaks of normals in blender... very annoying but it just might be a blender bug/problemFarbigeWelt wrote: ↑Tue Aug 06, 2019 9:48 amActually I did not expect anything else from someone with experienced skills. But even close to perfection people forget sometimes the simplest things.lacilaci wrote: ↑Tue Aug 06, 2019 7:12 am
