Warning: SetThreadGroupAffinity failed
marcatore
Post by marcatore »
I've these errors during the rendering phase.
I'm using OpenCL with "use CPUs" option ON and with Autodetect option enabled.
Anyone else?
Re: Warning: SetThreadGroupAffinity failed
This warning comes from OIDN, you could try looking into their docs or opening an issue in their repository to ask about it.
In my case, denoiser version didn't match (.exe & .dlls inside bin folder) to that which is specified in the code (exporter). Comes from mixing versions. You can disregard the message or make a new, fresh & clean install.
kintuX wrote: Tue Jul 23, 2019 2:39 pm In my case, denoiser version didn't match (.exe & .dlls inside bin folder) to that which is specified in the code (exporter). Comes from mixing versions. You can disregard the message or make a new, fresh & clean install.
It is likely to be a mismatch between Oidn DLL and TBB DLL.
Dade wrote: Tue Jul 23, 2019 4:10 pm
Aha, most likely it is. Cuz I rember, before OIDN was updated to the latest 0.9.0 I already used it, but had only overwriten exe & dlls. And since there were no issue rendering wise, i didn't pay much attention to it. Anyways, thanks for the tip! Nice to know.
acasta69
Post by acasta69 »
Dade wrote: Tue Jul 23, 2019 4:10 pm It is likely to be a mismatch between Oidn DLL and TBB DLL.
kintuX wrote: Tue Jul 23, 2019 6:44 pm Aha, most likely it is. Cuz I rember, before OIDN was updated to the latest 0.9.0 I already used it, but had only overwriten exe & dlls. And since there were no issue rendering wise, i didn't pay much attention to it. Anyways, thanks for the tip! Nice to know.
Strange, the TBB DLLs in WindowsCompileDeps should also be updated to the same version used by OIDN:
https://github.com/LuxCoreRender/Window ... 45ceeb7dea
acasta69 wrote: Wed Jul 24, 2019 9:17 am Strange, the TBB DLLs in WindowsCompileDeps should also be updated to the same version used by OIDN:
Not sure if it has any implication here but there is always the potential problem of Embree and Oidn being compiled for 2 different TBB versions.
Fox
Post by Fox »
But the TBB actually has more files than this 2 dll, it has around 120 files. :roll:
acasta69
Post by acasta69 »
Fox wrote: Wed Jul 24, 2019 10:35 am But the TBB actually has more files than this 2 dll, it has around 120 files. :roll:
The full TBB is larger, but we use directly the Intel binaries for OIDN, and the distribution contains only the required TBB dlls + libs, total 4 files.
We need more stuff for Embree, however, and:
Dade wrote: Wed Jul 24, 2019 9:41 am Not sure if it has any implication here but there is always the potential problem of Embree and Oidn being compiled for 2 different TBB versions.
I also don't know how it could affect us. I'll try to investigate a bit deeper.
EDIT: BTW, an issue about this is already present in OIDN repo.
