What will happen to rays that emit from the source while using BiDir?B.Y.O.B. wrote: ↑Thu Jul 04, 2019 4:08 pm lighting_freak wrote: ↑ What does happen internally while deactivating the auto detection and simply don't enter anything in that appearing menu? Do all my rays start in silicone then, the light- and eye path?
The rays will check if the material they hit has an exterior volume set and use that as their assumed starting volume.
I mean in my setup are rays that see through the silicone resin and will be set to air or silicone (the exterior is air in that case, but the beam has been emitted in silicone) Further more if an emitted ray hits the LED body first it will be in silicone since this surface is being defined as having exterior volume silicone. In that case we would have two classes of rays from the the same emitter.
BR
