Thread limit
Thread limit
there is no limit right i know blender has built in limit of 1024 but you can just open another instance to get another 1024 is luxcore render the same?
Re: Thread limit
There is no limit in the number of threads LuxCore can use. May be BlendLuxCore has a limit in place for the GUI
Re: Thread limit
Yes, because I use the Blender property with its auto-detection of CPU cores, but also with its limitations.
You can use any number you want if you edit this line of code: https://github.com/LuxCoreRender/BlendL ... fig.py#L87
If you use the CPU in addition to an OpenCL GPU, you need to change this line:
https://github.com/LuxCoreRender/BlendL ... ig.py#L125
Re: Thread limit
very good boys logically and easy to follow unlike Kintux
Re: Thread limit
What is this supposed to mean?
