Analog film simulation file format
wasd
Post by wasd » Tue May 21, 2019 8:20 am
What is the format of a file for analog film simulation preset?
CPU Bidir (sometimes GPU Path) + Metropolis | Log Power | Core i5-4570
Re: Analog film simulation file format
Post by Sharlybg » Tue May 21, 2019 8:47 am
Seem to be .crf
But we talk to support 3d LUT file format like .cube
wasd
Post by wasd » Tue May 21, 2019 9:07 am
Seem to be .crf
May I ask, .crf is what? I've asked google and received very confusing result.
Post by Dade » Tue May 21, 2019 10:28 am
There is a list of predefined camera responses (https://github.com/LuxCoreRender/LuxCor ... e.cpp#L429) and you need to use the name as file name (i.e. the name will be recognized and a corresponding internal pre-defined LUT will be used).
Otherwise you can write a .crf file: it is a text file with a table to translate each RGB color from a value to another (I have to check the parsing code if you need the exact format).
wasd
Post by wasd » Tue May 21, 2019 12:13 pm
I would like to know the exact format to make my own presets, if it's not too much trouble.
Post by Dade » Wed May 22, 2019 2:19 pm
A database of 201 response curves can be downloaded from http://www.cs.columbia.edu/CAVE//softwa ... b/dorf.php (the direct link to the file is http://www.cs.columbia.edu/CAVE//softwa ... Curves.zip)
It is a single text file with all 201 response curves. LuxCore will read the first one available inside the file (so copy the one you are interested in a new text file or write your own using the same syntax).
This is an example of Ektachrome-320TCD camera response file:
Ektachrome-320TCDRed
graph-log-log-pos
I =
0.0   [... a long list of values ...]   1.0
B =
Ektachrome-320TCDGreen
graph-log-log-pos
I =
B =
Ektachrome-320TCDBlue
graph-log-log-pos
I =
B =
Values are between 0.0 and 1.0. You map Red/Green/Blue "I=" input values in Red/Green/Blue "B=" output values.
Fox
Post by Fox » Thu May 23, 2019 10:42 am
My method for converting any film simulation from any image editor to crf data under B = data field.
B data fields have 1024 numbers going from 0 to 1.
Therefor i need linear gradient image file with measures 1024 pixel by 1 pixel,
grayscale, but saved in rgb format 32bit float, where values go from 0 to 1.
Apply film simulation to that image file.
Convert R G B channels to separate image files,
saved in grayscale 32bit float.
Open image files with hex editor and view in float format.
Copy normal looking numbers (not e-38) and paste here https://www.browserling.com/tools/spaces-to-newlines
Hit convert spaces, and copy data back to openoffice calc.
You should have 1024 values, if everything looks ok,
then you can set number format in openoffice calc to look like 9.775171e-004
Copy all numbers and paste here https://www.browserling.com/tools/newlines-to-spaces
Hit convert newlines.
Copy data to openoffice writer.
Search spaces and mass replace all single spaces with 3 spaces.
Copy data to crf file under B = line
Do this all with all the R and G and B image files for all the 3 B = fields.
Post by Sharlybg » Thu May 23, 2019 11:32 am
Hi fox !
Do you think it is also possible to convert LUT .cube format in to CRF file ?
Fox
Post by Fox » Thu May 23, 2019 11:52 am
Hi fox !
The lut cube values go also from 0 to 1.
:roll: Is this really that easy to copy and paste, not sure.
The crf has 1024 values, but cube that i looked had 32768 values.
Does it matter, i think it would work.
Post by Dade » Thu May 23, 2019 5:35 pm
CRF can have any amount of values, you have only to have the same number of in and out values, it is the only constrain.
