texture nodes for world hdri
Post by lacilaci » Thu May 16, 2019 11:15 am
In cycles I can use hsv controls to control colors of my hdri in blender, can't seem to find a way to do this in luxcore?
Is it not doable?
Re: texture nodes for world hdri
Post by B.Y.O.B. » Thu May 16, 2019 3:12 pm
Currently, LuxCore light source settings are not node-based, they don't support arbitrary textures as input.
For example, in the infinite light properties, I can only specify the file to load and some additional properties: https://wiki.luxcorerender.org/LuxCore_ ... :_infinite
(the infinite light is exposed as "HDRI" mode in the Blender world settings)
Post by Dade » Thu May 16, 2019 6:52 pm
However they are standard image maps with all connected pre-processing features available (like channel selection, gamma correction, color average, etc.).
Adding HSV pre-processing and exposing the feature would be quite easy.
Post by B.Y.O.B. » Thu May 16, 2019 7:09 pm
I think it would be better to implement a node system for lights. HSV corrections is just one of many things people might apply to a light's color.
Of course it's also more work.
Or did you mean, add HSV to the pre-processing steps of imagemaps?
Post by epilectrolytics » Thu May 16, 2019 7:42 pm
It would be great if procedural nodes for clouds or stars could be added to the sunsky or general background like it is possible in Cycles.
Post by Dade » Thu May 16, 2019 10:25 pm
Evaluating textures inside light sources may be quite deadly for OpenCL (as usual the problems are there). It is trivial to do on CPUs, not really on GPUs.
I did.
Post by lacilaci » Fri May 17, 2019 5:04 am
Actually, HSV controls might be enough for hdri. Some hdri's have a bit crazy and oversaturated colors so this might provide quick way of handling this.
also maybe a mirror option as an addition to already present rotation controls... I think that's about it. more detailed tweaks might be better done in other software.
Post by B.Y.O.B. » Fri May 17, 2019 11:06 am
This is already possible if you use a hemi lamp instead of the world settings.
You can set the hemi lamp scale to -1 to mirror the image on that axis.
