Error opening image file
Taka
Post by Taka »
I've been working on a large scene(Archviz, a condo building) and I get this error quite often. I have many append/linked objects in the scene and it seems they are causing this problem. I read somewhere that clearing temp folder solves this but it works sometimes but not always. I have noticed this happens even with a simple scene when I append materials. I use an add-on "Asset Management" for appending/linking since this add-on speeds up my work-flow greatly.
Can anyone tell me why this error happens and how to avoid it? I really want to use LuxCore in my workflow but a few things are slowing me down and this is one of them.
One thing I notice though, when I use render management program (RenderPilot), this error hasn't happened yet so far. I don't know if it's relative...
Re: Error opening image file
Thanks for your report.
Could you copy/paste the full error message?
Can you upload a small scene that shows the problem, including the problematic image file?
By the way, there's a known problem with packed DDS files: https://github.com/LuxCoreRender/BlendLuxCore/issues/70
Taka
Post by Taka »
B.Y.O.B.,
Thanks for your quick reply.
Here is a sample of the error
Error message:
Error opening image file : C:\Users\Taka\AppData\Local\Temp\tmpw8ahv6yv.jpg (error = Empty file "C:\Users\Taka\AppData\Local\Temp\tmpw8ahv6yv.jpg")
What's the limit file size I can share here? I'm trying to upload one but it says the file is too large. The file size is just over 20mb
Does it also happen if you unpack the image before exporting?
You can find out what the original image name was with the following steps:
- Open Blender console (Window -> Toggle System Console)
- you will see the log messages of the export in a new window. Right click the title bar of this window and try to find a menu entry that lets you copy all the text (something like select all, then copy, or so - I hope that's possible)
- paste the log messages into a text editor
- use full text search to look for the name of the temporary image in the log messages. The line should look like:
Unpacking image "Wooden-Background-213.jpg" to temp file "/tmp/tmpjmwys1vx.jpg"
Of course you can also look through the log messages manually, if the scene is not too big.
About uploading the image/scene: you could use an external filehoster.
Taka
Post by Taka »
B.Y.O.B. wrote: Mon Apr 15, 2019 7:57 pm Does it also happen if you unpack the image before exporting?
I will try it next time but which unpack option should I use in this case?
I would try "Use file in original location", but it doesn't really matter.
Taka
Post by Taka »
I tried unpacking (tried a few different options), some linked objects lose their materials(rendered in pink). Sample error log goes like this:
Node "Imagemap" in tree "Leather_Brown": Could not find image "AI43_002_leather_color_01.jpg" at path "//textures/AI43_002_leather_color_01.jpg" (Not an existing file: "E:\Dropbox \Taka\Blender 3D\assets\Furniture_LuxCore\Chair\blends\textures/AI43_002_leather_color_01.jpg")
But is this the same image as before?
It would help a lot to have a small scene showing the problem.
Taka
Post by Taka »
I completely understand. The problem is this error happens randomly so the same file has the problem one day, then next day it doesn't. I know it would help you troubleshoot if I can constantly recreate the issue and give the scene.
I'm wondering if this happens to other people though.
I'll share if I come across a file that happens constantly, or at least often. Thanks for trying to help me with this.
Taka wrote: Tue Apr 16, 2019 7:10 pm I'm wondering if this happens to other people though.
Among the reported issues, I only remember the DDS problem and someone with russian locale and russian characters in filenames. A case like yours was not reported yet I think.
The randomness sounds weird. Maybe some other addon/program interfering? Does the disk have enough space?
