Caustics cache strange variation
Hi just testing cautics cache on different scene size and just catch a weird behaviour :
The pool brightness vary according to scene size.
Smaller ground plane give darker pool :
big ground plane give brighter pool :
Here is the blendfile: you can just increase the ground plane by 10X to see the difference:
pool.blend
(1.96 MiB) Downloaded 125 times
[/size]
Re: Caustics cache strange variation
The total size of the scene affects where the rays for sun, sky and infinite lights are emitted from (they are emitted from the bounding sphere of the scene). Also floating point numbers have less and less precision farther you are from the origin. This is likely to be the source of your problem.
Metropolis is likely to start to have numerical precision problems: it will have to hit a smaller and smaller pool, larger the scene is. Quoting myself from another post:
Something that works at a scale X or position XYZ, will not work if scale up or translated far from the origin.
This is a rendering where you can literally see the floating point bits, near the origin:
far from the origin:
even father away:
Quite insane, isn't it ?
Images courtesy of Matt Pharr article: https://pharr.org/matt/blog/2018/03/02/ ... space.html
Hmm that well explain.
Thanks.
Post by FarbigeWelt »
Dade wrote: Mon Jul 26, 2021 11:36 am Quoting myself from another post:
even father away:
That is probably mostly a not intended effect, is it?
But, I truly like it! :geek:
However, 64 bit precision would be appreciated sometimes.
If only performance costs did not more than double or quadruple at most.
MacBook Air with M1
FarbigeWelt wrote: Wed Jul 28, 2021 7:06 pm However, 64 bit precision would be appreciated sometimes.
I think the reason we will never really have a transition to FP64 is more because of doubling memory (and bandwidth) usage is too impractical than the performance hit.
But we are literally rendering images with Lego (aka bits) at the moment.
Dade wrote: Wed Jul 28, 2021 9:31 pm
Well, this is probably closer to reality than many people are aware of.
"One can truly think our World is built on Cubes - Cubes are as a matter of mathematically proven fact the most probable shape out of all kind of fragmentation shapes - at least in our three dimensional material word.", 2021, FarbigeWelt
What? :o Why? :shock:
Please, have a look at following paper.
Plato’s cube and the natural geometry of fragmentation
Gábor Domokos,
View ORCID Profile
Douglas J. Jerolmack,
View ORCID Profile
, and
View ORCID Profile
János Török
1. aMTA-BME Morphodynamics Research Group, Budapest University of Technology and Economics, 1111 Budapest, Hungary;
2. bDepartment of Mechanics, Materials and Structure, Budapest University of Technology and Economics, 1111 Budapest, Hungary;
3. cDepartment of Earth and Environmental Science, University of Pennsylvania, Philadelphia, PA 19104;
4. dMechanical Engineering and Applied Mechanics, University of Pennsylvania, Philadelphia, PA 19104;
5. eDepartment of Theoretical Physics, University of Debrecen, 4032 Debrecen, Hungary;
6. fDepartment of Theoretical Physics, Budapest University of Technology and Economics, 1111 Budapest, Hungary
PNAS August 4, 2020 117 (31) 18178-18185; first published July 17, 2020; https://doi.org/10.1073/pnas.2001037117
Edited by David A. Weitz, Harvard University, Cambridge, MA, and approved May 27, 2020 (received for review January 17, 2020)
MacBook Air with M1
Make me wonder if cacheless caustic solution will also suffer the first post issue :?:
Sharlybg wrote: Fri Jul 30, 2021 7:38 am
Place the camera under water, disable cache, enable light tracing and you can check (I don't know the outcome).
