How to get clear glass?
HemiMG
Post by HemiMG » Mon Jun 07, 2021 6:34 am
I'm trying to make an eye shader. The cornea needs to be clear, and it needs to refract the iris. This is giving me headaches. I'm using a glass shader for the out shell with the cornea on it. If is set the glass shader with an opacity of 1, the refraction works great but the eyeball gets dark. If I decrease the opacity of the glass, the eyeball returns to it's normal color but the refraction goes away. I realize glass will always impart some color, but I'm hoping there's a way to minimize it as it's quite strong. I've attached an image that shows the simple switch I created to go between the two shaders and the output both create.
Re: How to get clear glass?
Post by B.Y.O.B. » Mon Jun 07, 2021 8:51 am
Try to set the shadow color of the outer shell to white (this setting is in the advanced options in the output node).
HemiMG
Post by HemiMG » Mon Jun 07, 2021 5:15 pm
Thank you! That did indeed work.
DionXein
Post by DionXein » Fri Jun 11, 2021 11:36 pm
May I ask a question - why Glass and volume parameters didn't automatically update shadow color? It's a little bit counterintuitive. And why there is an option such as shadow color?
Post by Sharlybg » Sat Jun 12, 2021 8:59 am
shadow color is a cheap trick to compute glass simillar to corona hybrid glass. it look physically plausible but
it is not the way thing work in reality. but this trick is look better than archglass for example while saving us a ton of compute time.
it also help to set image background on plane that should let light pass through. same also when you create a light lamp surrounded by
a glass frame or bulb. In this case any light ray from the lamp become expanssive caustics we dont wannt to pay for all the time. So by making
shadow color white you bypass this computation with a nice result at a fair price ;)
DionXein
Post by DionXein » Sun Jun 13, 2021 9:49 pm
Okay, sounds legit :roll:
