at first I have to say, that I am quite new to blender, luxcore and 3d in general. So maybe I get something wrong or I just don't know how to do it. Please have patience with me
Here is my question:
I try to combine 2 different roughness maps to give the material even more variation. So my plan was to use the color-math node and switch the mode to "mix". As I understand "Fac" regulates how much of which rougness map I can see. When I try to do the same in cycles I use the mix rgb node and it offers even more blending modes like "overlay" which seems to give more the result what I am looking for. For me it seems that "overlay" gives a better representation of both roughness maps at the same time. Is there something similar in luxcore like "overlay"?
I attached 2 pictures and maybe you can see what I mean.
Many thanks in advance!
Question regarding Mix-Node (Color Math)
Re: Question regarding Mix-Node (Color Math)
Classic bump mapping is not additive (i.e. if you add/mix 2 bump maps, the result is not the sum of the bumps). So operations over many bump maps are not very intuitive. There have been alternative solutions proposed over the years but pretty much everyone are still using the same classic bump mapping algorithm.
Said that, you can just pre-process the bump maps in Gimp/Photoshop/etc. and then use the baked result. There is is really no reason to mix the images at rendering time if you can mix them as pre-processing (i.e. pre-processing is faster). I think you can even bake the mixed bump maps in Cycles and than use the result in LuxCore.
You can google how the "overlay" algorithm works in detail (it should be a rather simple equation) and perform it with math nodes.
For example here: https://www.deepskycolors.com/archive/2 ... modes.html
@Dade: Mael2 is talking about mixing roughness maps, not bump maps.
Thank you very much for your response. I will try to recreate it with the math nodes but I am a little sceptical that I'll succeed (I am such a noob ).
Is there a possibility that more blending modes will be added in future releases?
I want to thank you for providing such an incredible render engine and all that for free! I hope luxcore will get more attention in the future as it deserves it.
I did this once. I just want to prepare you what it looks like, as BlendLuxCore does not support NodeGroups...
Before you ask, no, I don't still have the .blend file
Hi. I would like to join this request for more colormath blending modes as using math nodes is not user friendly. Just check how many operations has mixrgb in cycles. I am really missing overlay and screen modes
