Problem with IES file
XRaf
Post by XRaf » Sun Apr 18, 2021 9:51 am
Hello
I uploaded several .IES files and they work but with these from Philips LuxBlender it doesn't render and shows an error.
These Philips files work with other software, is anyone kind enough to check? Thanks
https://www.lighting.philips.it/prof/la ... rtcolor-mv
The page that will appear contains several bulbs of the same type and you just need to download a random file. I tried the 50W 36 ° 2700K and the 35W 25 ° 2700K.
In this post I only write about the render preview and Luxcore 2.5 with Blender 2.92, both commercials have IES files and there is the Philips one.
Turning off the light on the left, Philips freezes but I also noticed that turning this off and turning the other back on again, you have to switch to the wireframe and return to the render preview to see it.
Thanks and I hope it will be useful for other people too
test IES.blend
(793.34 KiB) Downloaded 15 times
Re: Problem with IES file
Post by Dade » Mon Apr 19, 2021 10:25 am
I downloaded the first one (https://www.docs.signify.com/assets/ies ... 5d-ies.ies) and it is working fine here :?:
P.S. you can pack the .ies files with the .blend in a .zip file.
XRaf
Post by XRaf » Mon Apr 19, 2021 1:37 pm
I send you file zip with IES,
Thank you
Test IES 1.zip
(195.14 KiB) Downloaded 11 times
Light
Post by kintuX » Mon Apr 19, 2021 7:59 pm
Looks fine... :?
XRaf
Post by XRaf » Tue Apr 20, 2021 7:40 am
Thanks for trying, I'm glad that it works for you but in the previous screens you can see "error" only on the philips file. Not a big deal because I find other files but in my opinion there is some conflict either in the software or in the configuration I have ... I don't know. Thanks anyway
Light
Post by Dade » Tue Apr 20, 2021 8:30 am
It is working for me too.
Is your system configured to use "," instead of "." as decimal separator ?
Post by Dade » Tue Apr 20, 2021 8:37 am
It is likely to be this problem. I should have fixed it in v2.6.
XRaf
Post by XRaf » Tue Apr 20, 2021 11:48 am
Can you tell me how to change "." "," ?
Is about win10?
Light
Post by Dade » Tue Apr 20, 2021 1:45 pm
Is about win10?
Yes, it is the somewhere in locale/language system settings (I don't know exactly I use Linux). Are you from a European country using "," instead of "." as decimal separator ?
acasta69
Post by acasta69 » Tue Apr 20, 2021 2:01 pm
It is in Control Panel --> Region --> Additional settings
Normally the first setting (decimal symbol) is "," in European countries, while the "digit grouping symbol is "."
Try if swapping them fixes your problem.
