Hi all,
I`m running into some issues while testing the "network rendering".
My operating system in Windwos 7.
First I was trying to open LuxCore network render from Blender.
After pressing the button an GUI appears that allows me select betwenn NetNode or NetConsole.
OK that seems to work like described in the wiki, but after selecting one of these options nothing else happens.
My next attempt was running the pyluxcorettols.exe from Desktop, but that leads to identical result.
Last test I did was running the *.exe from command prompt and at least I'm receiving this error message after selection of NetConsole:
C:\>C:\Users\Martin\Downloads\luxcorerender-v2.1alpha4-win64-opencl\pyluxcoretoo
l.exe
ImportError: numpy.core.multiarray failed to import
ImportError: numpy.core.umath failed to import
During handling of the above exception, another exception occurred:
File "pyluxcoretool.py", line 74, in <module>
File "C:\Users\Martin\AppData\Local\Temp\_MEI52322\pyluxcoretools.zip\pyluxcor
etools\pyluxcoremenu\cmd.py", line 59, in main
etools\pyluxcorenetconsole\ui.py", line 442, in ui
SystemError: <Boost.Python.function object at 0x0000000002BD1580> returned a res
ult with an error set
[1724] Failed to execute script pyluxcoretool
Slightly different message while selecting NetNode option:
l.exe
File "C:\Users\Martin\AppData\Local\Temp\_MEI56362\pyluxcoretools.zip\pyluxcor
etools\pyluxcoremenu\cmd.py", line 57, in main
etools\pyluxcorenetnode\ui.py", line 125, in ui
SystemError: <Boost.Python.function object at 0x0000000002BD5530> returned a res
[324] Failed to execute script pyluxcoretool
Does anyone know what`s wrong?
Thanks for helping me.
BR
