Network Render and transparent Film not working
Flink
Post by Flink »
Hi all,
i encountered a problem when using Networkrendering in combination with transparent film. When rendering the scene directly from Blender everything works fine. But when exporting the scene and rendering with Networkrender the Background is gray.
I'm using Bidir Renderengine. Do I miss something or is it a Bug?
Re: Network Render and transparent Film not working
I did it like that in BlendLuxCore because luxcoreui doesn't display the alpha channel. Network rendering came later and I didn't change the behaviour.
You can workaround it by enabling the "Alpha" AOV in the renderlayer settings and use the result in compositing after the network render is done.
Flink
Post by Flink »
Thank you for your answer B.Y.O.B. This workaround is fine for me.
