Use spot light sources and/or fix the cauchy value you used: it is very small, if you want drammatic rainbows, use something in the range of [0.1, 0.2].
Cold Fusion
Re: Cold Fusion
Re: Cold Fusion
It is perfectly ok to use 0 W and 0 efficacy. In such a case the brighness is only controlled by the gain.
It's a bit counter-intuitive, I know.
Only if you set the gain to 0 you get a "switched-off lightsource".
Re: Cold Fusion
Hey guys,
many thanks for this great example. However, I can't get the lasers showing up the right way, even when the world volume is set. What do I need in order to make that work? Any advice would be awesome.
Thanks & Cheers,
Christian
- Attachments
- Prism2-with-lasers-test.blend
- (669.61 KiB) Downloaded 194 times
Re: Cold Fusion
Have you fixed the volume setting of the world? Dade found that it was wrong in the .blend:
viewtopic.php?f=3&t=75&start=20#p1071
Re: Cold Fusion
Thanks for your quick reply @B.Y.O.B. Yep, already tried adding a homogeneouse volume to the enviroment. The outcome is also pretty nice but looks quite different . Not sure what I'm doing wrong...B.Y.O.B. wrote: ↑Sun Jun 09, 2019 7:44 pm Have you fixed the volume setting of the world? Dade found that it was wrong in the .blend:
Re: Cold Fusion
When I use a homogeneous world volume with default settings, it looks to me like I get a correct result.
I disabled all but one laser so the result can be checked easier.
By the way, I have switched to Metropolis sampler which is better for these kind of scenes.
There's still no option to set the volume of lights, I wonder if that plays a role here.
- Attachments
- Prism2-with-lasers-test_2.blend
- (677.64 KiB) Downloaded 188 times
Re: Cold Fusion
Thanks again @B.Y.O.B. Yessssss! You are correct, my fault. I've accidentally added another interior to the bounding volume while fiddling with the values. Now we're getting something similar, brilliant! Also the outcome is indeed way nicer using metropolis sampling, thanks for adjusting my render settings.
However, I wonder why the actual prism has no depth to it...? What I'm missing here?
Thanks & Cheers,
Christian
Thanks & Cheers,
Christian
- Attachments
- Prism2-with-lasers-test_3.blend
- (677.34 KiB) Downloaded 195 times
Re: Cold Fusion
The prism has no interior volume set (= clear volume), so the light just travels straight through and is not visible from any other than the outgoing direction.
In theory, the beams would become visible if you use a homogeneous volume for the interior of the prism.
However, I could not get them to show even with that - I suspect that these are SDS paths (specular-diffuse-specular) which Bidir is unable to render.
Maybe Dade can comment if this is correct.
By the way, try a clear volume with colored absorption for the prism. Looks quite cool.
Re: Cold Fusion
Yes, you are but you could remove the top face of the prism (or extrude the prism up to the point to include the camera) so it is not an SDS path anymore (i.e. you are removing the specular surface).B.Y.O.B. wrote: ↑Mon Jun 10, 2019 4:53 pm In theory, the beams would become visible if you use a homogeneous volume for the interior of the prism.
