Productviz / Packshot by Juliano Lisboa
Re: Productviz / Packshot by Juliano Lisboa
Thank you friend, I forgot to thank you for the praise of Zupp's work.
Reviews are always welcome
I do love how you can see through the little tube that goes up to the top but should that be full with liquid?
It looks like you have not set enough light bounces - can I recommend setting everything except Diffuse to at least 32? This will remove/reduce the black edges on the glass, which IMO detracts from the realism because it is quite characteristic of a render with not enough light bounces. It might also change the super dark shadow on the box at the back.
If you had time I'd also love to see a version with BiDir or Light Tracing and/or PhotonGI Caustic enabled
Excellent render visualization Juliano!
