Simple Test Scene
Martini
Re: Simple Test Scene
Post by Martini » Fri Nov 29, 2019 9:37 am
epilectrolytics wrote:
Fri Nov 29, 2019 9:24 am
(Somehow this does not automatically update after a new render, I always have to manipulate a node in order to get a screen refresh showing the intended result.)
That's because you have no halt condition - I assume you are hitting Esc to stop the render? If the render finishes on its own (with a halt condition) it will run the compositor automatically.
Magog
Post by Magog » Fri Nov 29, 2019 9:39 am
When in LuxCore the denoiser is activated, the render layers node in the compositor shows a "DENOISED" output, which you can mix with the image output (shows the undenoised render).
Tnx a lot!
I was expecting something much more complex.
Martini
Post by Martini » Fri Nov 29, 2019 9:46 am
Magog wrote:
Thu Nov 28, 2019 1:20 pm
Test on scene downloaded for free.
Looks amazing, can you share the blend file?
Post by Sharlybg » Fri Nov 29, 2019 9:49 am
With 2 Rtx 2080 and AMD ryzen 2950X... Yes.
With the kind of hardware you have it look like it is way too slow from my POV. like you're not using Gi caching and good Clamping value. the scene seem to be very simple.
Want to see the entire project with opening setting and lighting setup. i usually do 5 min render 1.5k resolution with i7 8700k.
Magog
Post by Magog » Fri Nov 29, 2019 9:58 am
1 minute and 58 sec at 1920 x 1080 is too slow?
Post by Sharlybg » Fri Nov 29, 2019 10:00 am
i mean this.
PetrT,in the last scene I used 5000 samples... 9minute for the render.
Magog
Post by Magog » Fri Nov 29, 2019 10:01 am
Also with mix node I've too many noise and lost some details..
5000 samples , 7 minutes.
Magog
Post by Magog » Fri Nov 29, 2019 10:02 am
i mean this.
The settings are all default ..
I don't know where to intervene to improve.
Post by Sharlybg » Fri Nov 29, 2019 10:11 am
So you don't have any caches on ?
Racleborg
Post by Racleborg » Fri Nov 29, 2019 10:17 am
For me it is still difficult to manage the Denoise, which makes me lose all the details.
2500 samples, and this is the comparison.
You may find that OIDN doesn't like small repeated patterns such as in the fabric weave and BCD works better for this. BCD takes a bit longer. But with OIDN, 1000s of samples may not make any difference in this situation.
