Smoke
Smoke
A frame from a short smoke animation I'm currently rendering.
Render time around 7 min (including 15 sec denoising) for 100 samples.
Edit:
Complete animation: https://youtu.be/l_YPrGoFPzQ
File Download: viewtopic.php?f=2&t=737#p7657
This is a continuation of my older smoke test: viewtopic.php?f=2&t=358
denoised
denoised
raw
raw
Re: Smoke
Very nice smoke can't wait for the anim :D
Asticles
Re: Smoke
Post by Asticles »
Amazing!
Re: Smoke
Post by lacilaci »
lovely...
Way back I did some sims with realwflow and also fumefx and krakatoa. I remember that rendertime was always a fraction of the time the simulation took. Is this simulated inside blender?
I know there are some tools but since forever I always consider simulating fluids very slow and it scares me lol...
Re: Smoke
I'll upload the scene when I'm done rendering so you can look at the settings.
lacilaci wrote: Fri Nov 16, 2018 8:13 pm I remember that rendertime was always a fraction of the time the simulation took. Is this simulated inside blender?
Yes, Blender smoke simulation, and in this case it's definitely the other way around. I think simulating took something like 15 minutes - then I rendered for a few hours until the noise and heat got on my nerves. I'll render the rest tomorrow.
Re: Smoke
btw You should consider to upload it as an official test scene.
Re: Smoke
Holly :mrgreen: smoke!
Re: Smoke
Here it is: https://youtu.be/l_YPrGoFPzQ
The file is attached.
You first have to free the bake in the smoke domain settings, then bake, then you can render.
Note that I used a file output node and halt conditions, you might want to turn these off for your tests.
Also be careful about RAM consumption, rendering a frame takes about 4.2 GiB RAM and 2.5 GiB VRAM.
The baked smoke data takes about 8.6 GiB of hard drive space.
smoke_another.blend
(114.88 KiB) Downloaded 341 times
Racleborg
Re: Smoke
Post by Racleborg »
The denoised image has worked well.
