Laci's wip
tokiop
Re: first steps
Post by tokiop » Mon Oct 22, 2018 6:45 pm
lacilaci wrote:
Mon Oct 22, 2018 4:44 pm
It is in the water, But I think that I will need to create a water tension geometry to get some highlights on contact.... This is where bevel shader with option to blend multiple objects would come in handy... also During this project I realized how much I miss triplanar mapping with blending from cycles :D
Indeed, surface tension seems tricky to make dynamically. It was also the case for volume intersections and we now have a nice and clean solution, so there is hope ! Could this be related to a shader-based bevel, sometime mentioned for CAD projects and others ?
Meanwhile, maybe baking a occlusion-type shader with a small radius, or dynamic paint addon, and using it as displacement map on the liquid, could help ?
Thanks for sharing your wip, the process and attention to the shaders, lighting and composition is inspiring !
lacilaci
Re: first steps
Post by lacilaci » Mon Oct 22, 2018 8:34 pm
Thanks, I will see if and how I will go about it.
Yes shader based bevel with the ability of including/excluding other objects would help here I think.
I don't like the idea of baking textures...
Anyway, I will deal with this once everything else is done, and maybe I forget and be happy with the result anyways... Or do it with actual geometry.
lacilaci
Re: first steps
Post by lacilaci » Tue Oct 23, 2018 5:44 am
Ok, so another problem.
If I want to render high res (4K+) I have to use tilepathocl cause denoiser won't let me use anything else.
However it seems some bright spots do appear as renderer progresses that won't go away, denoiser doesn't handle them as fireflies and I think those are unresolved caustics. So I hope this one actually is solved with the recent clamping+tilepath fix or rendering this on gpu is just not doable.
in attachment sobol vs tilepath, approximately same sampling level, note how the pool area shows "caustics?" in tilepath rendering
lacilaci
Re: first steps
Post by lacilaci » Tue Oct 23, 2018 7:19 am
Time to figure out the house design I guess...
Re: first steps
Post by B.Y.O.B. » Tue Oct 23, 2018 8:35 am
Nice progress.
Try to disable specular paths in the sun visibility settings.
lacilaci
Re: first steps
Post by lacilaci » Tue Oct 23, 2018 8:55 am
Nice progress.
Thanks a milion times... That helped, so I guess it was caustics then..? Interresting how they don't appear in normal pathtracing.
Re: first steps
Post by B.Y.O.B. » Tue Oct 23, 2018 9:08 am
Yes, the sun is an intersectible light source, so a unidirectional pathtracer can compute its caustics (but very inefficient when the sun is small).
zeealpal
Re: first steps
Post by zeealpal » Tue Oct 23, 2018 2:13 pm
Wow! Really liking how this is shaping up!
lacilaci
Re: first steps
Post by lacilaci » Thu Oct 25, 2018 11:48 am
A basic iteration on the design...
btw I wanted to try thick glass with 2 panes per windows(no archglass) The performance hit was insane :D gonna use archglass, but I guess having the ability to hide glass from gi would help and make glass pretty :)
lacilaci
Re: first steps
Post by lacilaci » Thu Oct 25, 2018 4:36 pm
A small tweak to the house and a quick and dirty late hour test..
