Laci's wip
Re: first steps
Post by B.Y.O.B. » Mon Oct 15, 2018 9:11 am
Here's the logo in svg format in case you want to use the exact shape :)
luxrender-logo-2012.svg.zip
(7.05 KiB) Downloaded 17 times
lacilaci
Re: first steps
Post by lacilaci » Mon Oct 15, 2018 10:03 am
thanks, now to figure out how to use those small circles
lacilaci
Re: first steps
Post by lacilaci » Tue Oct 16, 2018 6:35 am
ok, pool is in place
lacilaci
Re: first steps
Post by lacilaci » Tue Oct 16, 2018 12:05 pm
I want to add some 3d hills in the background.. But mist is causing trouble over treetops that are blurred unless I really push the mist further away. Can something be done about this?
lacilaci
Re: first steps
Post by lacilaci » Tue Oct 16, 2018 12:10 pm
changing, things around...
lacilaci
Re: first steps
Post by lacilaci » Fri Oct 19, 2018 12:02 pm
todays wip shot...
Re: first steps
Post by epilectrolytics » Fri Oct 19, 2018 12:43 pm
Awesome stuff, really great renders!
About the mist problem:
Instead of image pipeline (depth channel) mist you could try to mix the hill material with emissive background color.
MBPro 15" 16GB i7-4850HQ GT750M, MacOS 10.13.6 _________________Win10Pro PC Ryzen 2700X, RTX 2070, GTX 1060
provisory
Re: first steps
Post by provisory » Fri Oct 19, 2018 6:43 pm
I think, a volume would be the best for mist.
lacilaci
Re: first steps
Post by lacilaci » Fri Oct 19, 2018 6:48 pm
I removed the hills, didn't like the idea. What do you mean by mix with emissive background? Like composite those hill objects with background? or add emissive shader to the shader hills have?
Anyways I like the way mist works, excelent in camera solution. I hope that it is a bug that can be fixed.
lacilaci
Re: first steps
Post by lacilaci » Fri Oct 19, 2018 6:51 pm
I'm kinda worried it would be painfuly slow, however I haven't tried yet. Is there a world volume setting?
