Test scences GPU Path vs CPU BiDir
wasd
Re: Re:Strange effect using volume, CPU BiDir
Post by wasd »
FarbigeWelt wrote: Sat Jul 07, 2018 10:25 pm Yes, and as you can see, beam above spot of second spot light is not visible.
I think there is a beam. Your dust is just too thin. The reason why you have brighter beam above glass is that there's another beam going up, reflected from glass and wine.
I tried it with laser, it gives more evident beam.
But suddenly! I replaced dusty air with clear one and now there's some spectacular beam over the glass. The beam that should not be:
Re: Test scences GPU Path vs CPU BiDir
wasd wrote: Sat Jul 07, 2018 10:54 pm The beam that should not be
Did you also change the camera volume?
wasd
Post by wasd »
B.Y.O.B. wrote: Sat Jul 07, 2018 11:25 pm
Nope. It was Air and I changed Air volume itself.
wasd
Post by wasd »
Maybe I forgot dust somewhere though.
wasd
Post by wasd »
wasd wrote: Sat Jul 07, 2018 11:53 pm
Nevermind that. I experimented with beam disappearence and submerged everything in box of dust, changed external volume to that dust, then removed dust and forgot abot external volume. It is clearly my fault.
UPD: Nope. It was reversed normals on Wine.
wasd
Post by wasd »
It seems for me, light passing homogenous, scattering volume keeps scattering outside the volume.
I guess I'm done with my research on that matter. Air in your scene is not so dusty, that's why beam from second spot is barely visible. Beam from spot over wine is apparent because normals of your wine are reversed and (this is my guess) scattering is done with wine volume settings.
With simpler setup (even thickness glass tube) I've got following results:
1) glossy sticks (Sky for lighting)
2) laser beams (world lighting is None)
3) glass of wine — it takes a while though for beam to become apparent; 790 samples image
Would be nice to see B.Y.O.B. comment on that.
Some real life scattering as a bonus:
laser-10.blend
(711.31 KiB) Downloaded 215 times
Glass of Wine-5.blend
(868.11 KiB) Downloaded 211 times
I haven't yet read the discussion but are you aware that SDS (Specular-Diffuse-Specular) paths can not be rendered by a normal BiDir but they require BiDirVM (or something equivalent).
Note: a volume scattering point is considered a Diffuse path vertex (i.e. "D") while a glass intersection point is considered a Specular path vertex (i.e. "S").
Dade wrote: Sun Jul 08, 2018 8:54 am are you aware that SDS (Specular-Diffuse-Specular) paths can not be rendered by a normal BiDir but they require BiDirVM (or something equivalent).
But aren't the laser beams behind glass SDS paths?
In the past I always had the impression that LuxCore Bidir can in fact render SDS paths, however they converge very slowly.
wasd, the normals of the wine were indeed reversed which I did not check, nice find.
With correct normals (pointing outwards) this is what I get:
I think you're right that the still weakly visible beam of light we see over the glass coud be the reflection of the spotlight.
Nice render with the green lasers.
Glass of Wine 3.blend
(340.47 KiB) Downloaded 202 times
B.Y.O.B. wrote: Sun Jul 08, 2018 9:23 am In the past I always had the impression that LuxCore Bidir can in fact render SDS paths, however they converge very slowly.
Nope, it is like rendering caustics of a point light for a path tracer, it is just not possible (because the point light is a not intersectable light source so it can not be hit by a ray).
BiDir can not connect a light path and eye path when one of the end vertices is a specular event.
Re: Strange effect using volume, CPU BiDir
Thank you for the analysis and answers wasd, Dade and B.Y.O.B.
Although I checked the normals of the two objects, I made obvisouly a mistake for wine. It is not perfecly clear for me why Blender struggles sometimes with automatic normal setting for objects made by mesh spin. I see, I have to be more careful with direction of normals.
Sometimes it is not clear to me what is meant to exterior or interior, e.g. for a plane a 2D object with no volume.
Using laser is a good input. I should use laser too in 'dubious' cases. Their intense beam is good for tracing effects. At least lasers generate nice picutres.
By the way, congratulations for all coders and testers for the V2.0 speed, stability and very smooth UI integration in Blender.
Laser, Bragg, Dispersion and Volume
Laser, Prism, Volume Scattering
MacBook Air with M1
