Yellow Chairs
Re: Yellow Chairs
Post by B.Y.O.B. » Wed May 09, 2018 5:39 pm
zezic, did you note down the times in your material brightness test?
I compared images at equal render time, while you compared them at equal samples per pixel count.
Just a comment, I don't intend to sidetrack this into a testing thread ;)
zezic
Re: Yellow Chairs
Post by zezic » Wed May 09, 2018 10:30 pm
Hmm, I don't remember times, but I'll do more tests later and check this.
Racleborg
Re: Yellow Chairs
Post by Racleborg » Sat May 12, 2018 10:22 am
Hi Zezic
I've just noticed that there is no BUMP node being used on the floor. The Image map is being connected directly into the the Glossy material BUMP socket?
zezic
Re: Yellow Chairs
Post by zezic » Tue May 15, 2018 12:52 pm
Yes, and image map brightness decreased. Is Bump node necessary?
Re: Yellow Chairs
Post by B.Y.O.B. » Tue May 15, 2018 3:33 pm
No. If you look at the code, it is just a scale texture (aka multiply): https://github.com/LuxCoreRender/BlendL ... ump.py#L15
Racleborg
Re: Yellow Chairs
Post by Racleborg » Tue May 15, 2018 5:29 pm
That's makes a clean work flow!
Thanks
Luxart
Re: Yellow Chairs
Post by Luxart » Sun Jul 15, 2018 12:46 pm
These are rendered with Luxcore 2.1 alpha (with denoiser).
The render times are around 4 - 5 mins (CPU i74770K, GPU R9280x).
After denoiser the Luxcore speed jumps multifold. What do you guys think.
Area lights
Distant and area light
infinite and area light
The renders might not be clean. just did a quick test.
Zezic, Thanks for the scene. Useful for quick tests.
