A quick comparison between the different light strategies at 1 Sample/Pixel.
The used strategy is noted on the bottom left in the statistics.
Note how the Rays/Sample value is especially low (good) in the DLSC image.
Direct Light Sampling Cache Test
- spots.blend
- (162.58 KiB) Downloaded 247 times
Re: Direct Light Sampling Cache Test
The noise in the areas where multiple lights "overlap" per cache entry begins to vanish after about 70 samples:
- FarbigeWelt
- Contact:
Very nice post. It is hard to wait for all the improvements.
MacBook Air with M1
MacBook Air with M1
Surely I didn't understand the Samples/sec value. I understood that higher is better meaning that when the rays calculations are easy, the CPU (or GPU) can complete more rays calculation in the same time and it can sample more.
Nice to know that it's not like this.
No, you understood it correctly. I was talking about the Rays/Sample, which is computed as (Rays/Sec) / (Samples/Sec).
This statistic was not visible until recently. It tells you how long the light paths per sample are on average.
Short light paths usually mean less noise.
Oh..sorry.. I've misread!
And I've gained a tip about scene efficency.
Thanks a lot
Thanks a lot
