Dear B.Y.O.B.
Your very link points to the most fascinating development in computer history since GPT-3 last year demonstrations, that already set highest mark since A. Neumann, A. Touring and K. Zuse concreted the basement of all known productive computer designs in todays industries.
Sometimes, I ask the question, how could it be, most ingenious people of 20th century lived from begin of 1910s to end of 1950s. Although, engineers and scientists grew in relation to human global population far more faster as ever did in whole current known history leading data, information, knowledge increase at exponentially exponential rate.
Have you already heard about rather known quantum Hall effect is based on two spatial dimension physics, I hope you did.
Less known is, however, some scientists have seriously discovered
in their experiments data based on quantum Hall effect physical homologous effect, there must be a fourth spatial dimension then otherwise these scientists should not have been able to get experimental data as foreseen by their latest hypothesis regarding quantum Hall effect.
I know you are German, please, make your do your open mind a favor and read some parts in Stanislav Lem‘s Book: „Die Technologie Falle“. You should then be capable to take if you like some steps on the path I am used to walk alone from time to time since 1989, unfortunately only in my mind, because I failed to try to get in contact in with very notable people like Wolfram and his work, and may Knuth (the master mind behind of maybe most of useful standard algorithms).
Regards
FarbigeWelt (M. Trösch)
