Strange behavior during the rendering on the video card.
S0rda
Post by S0rda » Thu Feb 14, 2019 4:57 pm
Strange behavior during the rendering on the video card. I often notice that during the rendering I can hardly switch between applications and watch videos on YouTube, for example. Or, I can easily watch videos on YouTube and also switch between applications without any problems (I need to try running the crisis again, if only I had played it). In this case, the fundamental difference in the speed of rendering, I did not notice. That is, the video card is loaded at 99%, but nothing slows down, or again 99% and everything slows down.
In this case, I do not have a built-in video card in the processor, and both monitors are connected to the output of a single video card on the computer.
This behavior, I notice that when rendering on the luxrender, which is in cycles.
RicoS
Re: Strange behavior during the rendering on the video card.
Post by RicoS » Tue May 21, 2019 4:44 pm
Strange behavior during the rendering on the video card. I often notice that during the rendering I can hardly switch between applications and watch videos on YouTube, for example. Or, I can easily watch videos on YouTube and also switch between applications without any problems (I need to try running the crisis again, if only I had played it). In this case, the fundamental gimp freejobalert notepad++ difference in the speed of rendering, I did not notice. That is, the video card is loaded at 99%, but nothing slows down, or again 99% and everything slows down.
I am also facing this weird issue, does anyone have any ideas.
Help is appreciated,
Thanks in advance,
Regards,
Rico
Post by Dade » Tue May 21, 2019 5:55 pm
Windows has a quite bad threads schedular, as first step I would try to disable hybrid rendering (i.e. CPU+GPU) and to use only the GPU/OpenCL (this will leave the CPU free for other tasks and its contribution to rendering is often small anyway).
The different behavior across different renderings may be related to the complexity of the scene, simpler scenes will have faster OpenCL kernel execution time, allowing a faster execution of other application kernels too (i.e. reducing the latency to execute other app kernels).
