not sure where to post :)
Posted: Mon Jan 22, 2018 2:19 pm
by patro
Hi, i recently gave a try to luxCoreRender and i notice that the sample scene contained inside can't be loaded. unable to open cornell.scn
I have a request, it is just maquillaje, the UI of lucxore on 4k or retina monitor is almost not readable, could you add a way to increase the size of UI and dropdown menu by 200%.
thank you
Re: not sure where to post :)
Posted: Mon Jan 22, 2018 4:24 pm
It is a known problem, some path is wrong: https://github.com/LuxCoreRender/LuxCore/issues/51
Ctrl+Mouse Wheel will zoom in/out of any window, for some more keybindings related information: menu Window => Help or press 'h'. It work on Menu too.
But I guess it could be useful to have some persistent preference to set the zoom, for instance to 200%.
Posted: Mon Jan 22, 2018 8:04 pm
by patro
thank you Dade,
it would be useful a persistent preference.
I saw that there is in "screen" drop-down menu the preference to set the UI font size to 2.0.
if this could be flag and at every restart of luxcore remember this setting it would be awesome. This is also the only way to fix the dimension of the overlay that shows the rendering pass samples and so on information, even a portion below is cut off, text isn't entirely visible in it's whole height.
I guess I should report this in the bug tracker.
Btw i wasn't able to zoom in nor zoom out the image while rendering.
thank you.
Posted: Mon Jan 22, 2018 8:42 pm
If you are in camera edit mode (menu Tool => Camera edit), you move the camera with the mouse (not the image like in the old Lux). To "zoom" the image, just resize the window, the image is scaled up/down to fit the window (the rendering resolution remain the same aside the the aspect ratio).
Posted: Mon Jan 22, 2018 11:23 pm
by patro
thank you Dade,
but this doesn't work for me. When resizing the render window, the image remains the same, no auto fit. the rendering continues in the upper left and the rest is a gray background.
I'm on window 10 running on a bootcamp partition on a macbook pro with retina display.
Posted: Mon Jan 22, 2018 11:46 pm
What voice of Tool menu do you have selected ?
Posted: Tue Jan 23, 2018 1:40 pm
by patro
sorry for late reply, I've checked now. in tool menu "Image view" is set as default, and it's related to rendering resolution. I've checked this also on my window laptop.
While on a 4k or retina monitor, the highest render resolution like in this example image, or screen resolution with " image view" selected, will occupy around 1/4 of the screen, (see linked image),
Edited:
if you view the image you will see that the resolution of the screenshot on normal monitor 1800px X 2471px is
I suppose in this cases a zoom -/+ option would be good
from the image you can notice how the overlay at the bottom resizes when font size is set to 2.0
Thank you Dade for all your efforts also for caring about this tiny details.
Posted: Tue Jan 23, 2018 8:39 pm
I don't understand, "Image view" is not the default, "Camera edit" is :?:
Also the rendering in your picture looks wrong (I assume you are using the the example scene available in the download section).
Anyway, LuxCoreUI is not even included in BlendLuxCore, now that Blender 2.79a is available, you can use directly Blender.
Posted: Tue Jan 23, 2018 8:45 pm
No, it is included.
I should probably remove it, I don't remember why I put it in there.
