Bump Mapping Discussion
Posted: Tue Jul 02, 2019 6:24 am
by Racleborg
This topic was split from viewtopic.php?f=5&t=1080&p=14284#p14230
- B.Y.O.B.
Am I missing something here as I don't have a problem with the BUMP node unless my project dimension UNITS are setup wrong? Plugging the map into the BUMP HEIGHT, instead of the VALUE input, solves this for me.
Re: Material/Texture rework in v2.3
Posted: Tue Jul 02, 2019 6:49 am
by epilectrolytics
wasd wrote: ↑Sat Jun 29, 2019 3:35 pm
Currently,
bump doesn't work at all
In general I get it working with matte but not with glossy material.
Posted: Tue Jul 02, 2019 7:04 am
by Racleborg
by epilectrolytics » Tue Jul 02, 2019 7:49 am
wasd wrote: ↑Sat Jun 29, 2019 4:35 pm
Currently, bump doesn't work at all
This is what I'm getting. I think both look ok to me? (attached)
Posted: Tue Jul 02, 2019 8:10 am
by wasd
Racleborg wrote: ↑Tue Jul 02, 2019 7:04 am
Random patterns are bad for checking bump, because you don't know what to expect.
Posted: Tue Jul 02, 2019 8:24 am
by wasd
Racleborg wrote: ↑Tue Jul 02, 2019 6:24 am
wasd » Sat Jun 29, 2019 4:35 pm
Well, maybe inconsistency in height map caused by misconnected inputs.
But I'm not talking there about height map only. If you're using normal map, result is bad anyway. You can check with cycles for example, which doing bump well.
Posted: Tue Jul 02, 2019 11:14 am
by Racleborg
y wasd » Tue Jul 02, 2019 9:24 am
Thank you for the info, I'll be more aware of these possible issues in future projects.
epic recreation fail
Posted: Tue Jul 02, 2019 1:56 pm
by epilectrolytics
Indeed!
Though a value of 1 is quite extreme (probably means 1m bump depth) but nonetheless.
I remember two projects from last week where bump glossy failed me and have just tried to reconstruct them from memory but I couldn't!
Everything just works, as if secretly fixed in the meantime!
I vaguely remember there were roughness maps too so it could have been a no bump but roughness problem.
Another one was probably metal, not glossy.
This is so confusing!
Can someone tell me please if I'm supposed to be happy or angry now??
Re: Bump Mapping Discussion
Posted: Tue Jul 02, 2019 3:37 pm
by Racleborg
Unread post by epilectrolytics » Tue Jul 02, 2019 2:56 pm
"Don't worry. Be Happy" Bobby McFerrin. September 1988
Posted: Tue Jul 02, 2019 6:12 pm
by epilectrolytics
Sound advice
