If you want to see Python examples on how to move things around in Blender, i can recommend you my "Library.py".
You can download the whole package here for free:
Theo's External AddOn plus Library
It contains 2 Parts:
1. The Library - anyone can use it. "Library.py" the video shows how Libraries are registered in Blender.
     You can then add your own Subprogrammes there.
2. The "Blenderbar-AddOn". This one only works under windows. So its optional. You can see it on the picture below.
    As it docs at the right side of Blender, its completely version independent. The library not, i have just updated it so it works until at least 2.90.
The Library is in the Library folder. It contains a lot of Scripting samples how to select objects, move them around etc.
Many of this already in easy to use Python-procedures.
You may however need to watch a bit of the video there to see how its used.
To use the AddOn, you should know that it works only under Windows and it needs a Python console in the lower right corner of Blender.
Because it will type Python commands there.
Watch the Buttons:
- "Mul" this will multiply the selected Object in a defined cubic space
- "Rot" this will give all selected objects a unique random rotation within a given Frame number (and within a Speed range)
- "Mov" this will give all selected objects "Move" in random direction (limits)....
- "Siz:" this will give all selected Objects a random size within limits ...
Best you take a look in the Textfiles - this is where the Python Code for each Button (and the Button-Text) is located.
Note that it calls Subprogramms in "Library.py" (Button "Open Library") will open the Library Folder.
For writing Python I can recommend
Notepad++
Once you have the console in Blender open, you can start the AddOn, then press "Add Library".
This will register the Library Folder with Blender. The Free Public AddOn can have a total of maximum 20 Buttons which you can also put your own commands on.
If you want test the free AddOn. It is not limited other then it has only maximum 20 Buttons.
     If you like it ... then read ...
     There will be a new commercial add on, this will also include my desktops manager program (to have a own Desktop for each running Blender).
     Technically this is all ready. It can handle 40 Buttons (self configurable) and multiple Levels (up to 9 Levels with each 40 Buttons).
     So you can for example Make a Button-Level for Modelling, a Button-Level for Liquide-Simulation and a Level with your own functions for Rigid Body.
     My current problem is that i do not yet have so many useful functions to put it on all the buttons - thats why its not yet on Blendermarket.
     I will put it on Blendermarket when its ready. However if you like the AddOn, tell me.
    Any Programmer and contributor for Luxrender can ask me and then get the big-AddOn (the one with 40 Buttons and multiple Levels)
    for free (the blendermarket version). That includes my Desktops-Manager Program. The Library is the same in both packages.
