Shader view vs rendered image
tayo6
Post by tayo6 »
I was trying to make procedural planets with luxcore, issue was, i could see the effect come to live in the shader box, but
i don't see the effect in both preview port and rendered image.
Re: Shader view vs rendered image
Can you upload the scene?
tayo6
Post by tayo6 »
B.Y.O.B. wrote: Tue Mar 12, 2019 7:43 am Can you upload the scene?
Sample.blend
(502.98 KiB) Downloaded 500 times
tayo6
Post by tayo6 »
When I increased the noise size and distortion in the noise node, the effect became visible, but noise textures were stretched
tayo6 wrote: Tue Mar 12, 2019 9:31 am When I increased the noise size and distortion in the noise node, the effect became visible, but noise textures were stretched
It sounds like a scale problem, the size of the sphere is 0.1m, what is the scale of the cube ? You can adjust the 3D mapping (first node at left) scale and the preview sphere size (below the sphere input box) to match your cube.
tayo6
Post by tayo6 »
Dade wrote: Tue Mar 12, 2019 9:49 am
I adjusted the sphere size to the same size as the cube, both were 1.00 . Then I moved to the 3d mapping node, changed the size to both 1.00 and 0.01, yet I did get the desired result. I still didn't get it.
The "sphere size" is the diameter of the preview sphere, not the radius.
The default cube is 2m in diameter, not 1m.
So set the sphere size to 2 and it should work.
tayo6
Post by tayo6 »
B.Y.O.B. wrote: Tue Mar 12, 2019 12:15 pm The "sphere size" is the diameter of the preview sphere, not the radius.
Thank you, someone already helped me out. I used sphere 5.00 on the preview, which matched with the size of the rendered image. I learnt something new today. And I have to admit just like u told me last month, luxrender is easy to use
tayo6
Post by tayo6 »
Thanks, the issue was the sphere size.
