BlendLuxCore Development
Re: BlendLuxCore Development
Post by Sharlybg » Mon Apr 08, 2019 12:13 am
Thanks you very much. this is a great time saver :D . BTW can you try to check if it is possible to only have Volume type in volume search tool instead of volume + material ?
Post by B.Y.O.B. » Mon Apr 08, 2019 12:49 am
I have added a filter for the menu:
Post by B.Y.O.B. » Mon Apr 08, 2019 1:03 pm
I have exposed uvmapping3d in BlendLuxCore (available in the 3D mapping node).
It lets you use UV coordinates to map procedural 3D textures onto a mesh:
provisory
Post by provisory » Tue Apr 09, 2019 10:16 am
Looks promising, thank you!
Post by B.Y.O.B. » Thu Apr 11, 2019 12:16 pm
Entries in the error log now show a button that lets you select the problematic object with one click:
marcatore
Post by marcatore » Thu Apr 11, 2019 12:37 pm
Great! this is really good.
thank you
Post by Sharlybg » Thu Apr 11, 2019 1:04 pm
This is extremelly clever and usefull. thanks BYOB.
Post by B.Y.O.B. » Fri Apr 12, 2019 10:10 am
I have finally found a workaround to have "delete and reconnect" in our node editor.
The only weird thing for users is that the behaviour of [Del] and [Ctrl+X] is swapped ([Del] deletes with reconnect, [Ctrl+X] only deletes without reconnect).
Post by Sharlybg » Wed Apr 17, 2019 8:21 am
BYOB please do you if we have the possibility to add a node like pointness but this time to create such kind of effect :
https://www.youtube.com/watch?v=8G9Mbl-1_nU
Post by B.Y.O.B. » Tue Apr 23, 2019 9:53 pm
BlendLuxCore now supports the new adaptive sampling: http://forums.luxcorerender.org/viewtop ... 100#p12284
It is enabled by default if the sobol or random samplers are used.
