I should have fixed the problem.
PhotonGI cache
Re: PhotonGI cache
Yes, look at the code:
// Request the samples
const u_int sampleBootSize = 5;
const u_int sampleStepSize = 4;
const u_int sampleSize =
sampleBootSize + // To generate eye ray
params.maxPathDepth * sampleStepSize; // For each path vertex
const u_int sampleOffset = sampleBootSize + depthInfo.depth * sampleStepSize;
So if it still crash it should be something different, just re-run the new code under a debugger and post where the crash is.
Re: PhotonGI cache
My bad! for some reason the old version sits in the PATH before the new version so I was testing the old version ...
Now it doesn't crash anymore. Tried to render 10+ times. Thanks!!!
And looking closer at the code, I understood your fix: since depth starts from 0 instead of 1, sampleSize is always at least 4 larger than sampleOffset, so it will not crash at that point.
Re: PhotonGI cache
Is it a known issue or maybe intentional that PGI doesn't work on Mix Material, even if the mixed materials would work in themselves?
- epilectrolytics
Re: PhotonGI cache
MBPro 15" 16GB i7-4850HQ GT750M, MacOS 10.13.6 & Win10Pro PC 16GB Ryzen 2700X, 2 x RTX 2070
Re: PhotonGI cache
It should work but depends a lot on what you are mixing: there are parameters like glossiness or if a material is only DIFFUSE/GLOSSY/SPECULAR, etc. that may disable PhotonGI. For instance, if you mix "matte" with "mirror, PGI will disable indirect cache on that material because it can be "SPECULAR".
If you post a test scene, I can tell you what is going on.
Re: PhotonGI cache
I have this idea that might be a bit stupid but maybe not:
Would it be possible to control after how many bounces is photongi used? Maybe this would help with some reflection artifacting or leaks?
So maybe have 1 or 2 bounces brute force and afterwards sample from cache(a control exposed to the user).
The reason is that sometimes luxcore performs well in interior even without photongi but some areas are a bit "too deep" in terms of gi so they could benefit from photongi. However enabling cache might bring some artifacting even to areas which were ok and fast before. So I have to pick between artifacts and speed...
In my head I think this could help protect areas exposed to few bounces but still give speedup for hard to reach areas.
Re: PhotonGI cache
Here you go and Thanks!
(I know, that there is no point in mixing Glossy with Matte. It came up in this topic: viewtopic.php?f=4&t=1372)
- Attachments
- PGIvsMixed.blend
- (535.57 KiB) Downloaded 11 times
Re: PhotonGI cache
Ok, the problem was that mix (and glossycoatting) report their glossiness as Min() of the referenced materials and any not GLOSSY material report a glossiness of 0.0: so the result when mixing not glossy materials was always 0.0 (and PGI was disabled).provisory wrote: ↑Wed Sep 11, 2019 4:56 pmHere you go and Thanks!
I should have fixed the problem: now only the glossiness of GLOSSY materials is taken in account and this should fix the problem for mix (and glossycoatting).
