LuxCoreRender v2.1 released
Re: LuxCoreRender v2.1 released
Post by B.Y.O.B. » Sun Jan 13, 2019 1:47 am
Can you post a testscene that shows the problem?
Stem
Post by Stem » Sun Jan 13, 2019 2:51 am
Its a problem with missing materials.
If I import an object and any material zone's have not been given a Luxcore material, then I get the error/problem.
In previous builds, an imported object with missing Luxcore mats would render, and I would be given warnings about missing mats.
Do I need to post a test scene? You could import an object(.obj) and check.
Post by B.Y.O.B. » Sun Jan 13, 2019 10:28 am
Thanks for the report, I fixed the bug.
I think I'll wait a few days if any more bugs are found and repackage the BlendLuxCore release then (I don't think we need a v2.1.1 for only one bug, I can just move the v2.1 tag).
Stem
Post by Stem » Sun Jan 13, 2019 12:11 pm
Thanks for checking/fixing the bug.
Another issue, but it is unpredictable. When a render is in progress(just after starting), I can get an error showing(which stops the render) of:-
Report: Error
Writing to ID classes in this context is not allowed: Scene, Scene Datablock, error setting LuxcoreConfigPath.suggested_clamping value
The error can show, but when restarting the render(with no changes) it will render OK without the error.
Racleborg
Post by Racleborg » Mon Jan 14, 2019 1:07 pm
I've seen this happen a couple of times in the past. But when restarting the render the message has gone. I had presumed that, in my case, the error was a user error as opposed a software one.
