Problem with bump map
wasd
Post by wasd »
I can't get any bump from brick texure.
fBM diffuse color:
fBM bump:
Brick diffuse color:
Brick bump:
bump_bug.zip
(746.83 KiB) Downloaded 176 times
wasd
Re: Problem with bump map
Post by wasd »
Bump texture is grey background with black and white lines and black square on it.
Cycles bump:
Luxcore bump:
Look at the shadows at square depression.
test scene:
bump_bug_b2.zip
(90.3 KiB) Downloaded 206 times
hdri: https://hdrihaven.com/hdri/?h=green_point_park
wasd
Post by wasd »
edit:
Mango3
Post by Mango3 »
I would better use a normal or displacement map for these types of larger raised or embossed structures. Especially if you want to animate the scene and change view direction.
Bump maps are good for small surface variations like pores or wrinkles on a skin. They don't change the actual surface geometry, just fake the illusion of depth (normal maps are the same in this regard).
Maybe also check your surface normals.
Don't know much about this issue.
But overall I found it very hard to work with bump mapping. Sometimes higher values "break" the shader and sometimes they don't. Worse case was when in a scene where I was building asset everything looked ok, but then in main scene under different lighting it was wrong and I had to further tweak the shader... Not even mentioning how stronger bump exagerrates shadow terminator on round objects.
I hope that at some point this will get looked at cause it can be a big pain in the ass.
wasd wrote: Mon Nov 05, 2018 4:26 pm
The attachment b1.png is no longer available
The attachment b2.png is no longer available
The attachment bump_lines_2.png is no longer available
Works fine - you got your UV mapping rotated by 90°.
So, maybe it's this UV map orientation that's buggy?
I would imagine, no matter how the map is oriented, resulting effect should always depend on bump and lighting properties.
Lighting: Sun&Sky, Tonemapper: Analog Film - Kodachrome 200CD
& Couple of tips:
For "Bump" (Normal, Displacement, Roughness...) textures set Gamma to 1 (Linear) as feature expects "Value", not "Color".
To help your self orientate better apply the use of compass, especially with generic textures (ie. as in cartography).
wasd
Post by wasd »
kintuX wrote: Thu Nov 08, 2018 8:54 pm So, maybe it's this UV map orientation that's buggy?
Nope. It's obvious that's it's bump that's bugged. I don't think that's intended behaviour.
The result running inside Blender or with LuxCoreUI is different:
This explain some of the my confusion, I wasn't seeing the problem. This is quite strange, it may be a bug in BlendLuxCore :?:
Dade wrote: Mon Nov 12, 2018 8:43 am This is quite strange
It is caused by exporting:
scene.textures.139662654818312.mapping.uvrotation = 90
scene.textures.139662654818312.mapping.uvscale = 8 -8
scene.textures.139662654818312.mapping.uvdelta = 0 2
Vs.
scene.textures.139662654818312.mapping.rotation = 90.000002504478161
What ?!?!
Bug in UV mapping in LuxCore?
