it seems like the camera has no exterior volume property in LuxCore.
This leads to wrong renders if the camera is e.g. inside of a cube with a volume.
Can this feature be added?
Camera exterior volume
- Attachments
00005.zip- (20.9 KiB) Downloaded 541 times
Re: Camera exterior volume
Are you looking for world volume (scene.world.volume.default):B.Y.O.B. wrote: Mon Jan 22, 2018 10:17 pm it seems like the camera has no exterior volume property in LuxCore.
scene.volumes.vol_air.type = homogeneous
scene.volumes.vol_air.absorption = 0.0 0.0 0.0
scene.volumes.vol_air.scattering = 0.04 0.04 0.04
scene.volumes.vol_air.asymmetry = 0.0 0.0 0.0
scene.volumes.vol_air.multiscattering = 0
scene.world.volume.default = vol_air
I guess I am looking for that
Thanks.
edit: However, that would set this volume as default for all materials and lights, right?
What if I only want the camera to be in a volume, but not e.g. the sun?
I would have expected a "scene.camera.volume" setting.
Thanks.
The default volume is used when the object lack of volume definitions. Just use an object with null material and an interior volume and place the camera inside the object.B.Y.O.B. wrote: Mon Jan 22, 2018 10:54 pm I guess I am looking for that
Thanks.
This was the problem, thanks, it works like expected now.Dade wrote: Mon Jan 22, 2018 11:43 pm I am on a tablet at the moment, looking at your scene, have you assigned the monkey outside volume ?
