Open cl processor
Ezearebalo
Open cl processor
Post by Ezearebalo » Tue Oct 02, 2018 3:51 am
Hi im searching some "new" processor. But i dont understand something. The cpu need to have open cl 2.0 capability to speed up renders ? Look the image, i7 and fx 6300 doesnt have it ? I should buy a brand new processor ? Thanks
Re: Open cl processor
Post by B.Y.O.B. » Tue Oct 02, 2018 7:48 am
No. LuxCore uses native C++ code for CPU devices, OpenCL is only used for GPUs.
Also, the integrated GPUs in modern CPUs are not really capable of running LuxCore.
LanePanet
Post by LanePanet » Fri Jan 04, 2019 6:01 pm
As per my knowledge If you dump a clinfo application type of output against an Intel based OCL implementation, you'll see each core mapped to an OCL execution unit. The entire CPU will present itself as one OCL device. If you have a host thread active while kernels are active, a naive OCL runtime will gang schedule over the "Host" core.
turnkey pcb
Post by epilectrolytics » Fri Jan 04, 2019 9:28 pm
What about the Vega graphics in AMD Ryzen 2XXXG Processors?
Has someone tested those?
MBPro 15" 16GB i7-4850HQ GT750M, MacOS 10.13.6 & Win10Pro PC 16GB Ryzen 2700X, 2 x RTX 2070
Post by Dade » Fri Jan 04, 2019 10:38 pm
Some of the past AMD APU were working fine but you have to check case by case to be sure.
