shadow catcher
Posted: Wed Aug 30, 2023 9:11 pm
by modhob
hi,
i have something working using a shadow catcher. Is there a way to change the opacity/darkness etc of the shadow....without affecting the object casting the shadow. I can change the color of the shadow by changing the diffuse color of the plane material. But it's always semi-transparent. Is the shadow entirely dependent on the HDRI chosen? That doesn't seem right.
I am using an HDRI as lighting and can't seem to change those shadow properties. I tried using a different layer with the shadow catcher but couldn't get it to work. Basically the lighting wouldn't affect that layer for some reason
any help w screenshots is greatly appreciated
I'm using blender 2.8
Re: shadow catcher
Posted: Thu Aug 31, 2023 11:33 am
First, check the note above (in red) and also specify which LuxCore version you're using with Blender 2.8. :?
Can't you use newer LTS versions (3.3x & 3.6.x) w/ LuxCore 2.61 or 2.71 respectively?
Otherwise, yes, shadow color depends on lighting conditions & surface properties.
BTW
You should modify/play w/ shadow opacity in compositing.
Re: shadow catcher
Posted: Thu Aug 31, 2023 9:48 pm
by modhob
Ok I made a very simply scene whereby I simply want the monkey shadow on it's own layer so I can change it's opacity or do whatever else with it.
I can't upload the scene here because it's too big (the .exr file).
You can download the scene here:
https://gurglurator.com/blendertest.zip
The lux version is 2.2. I can't upgrade to newer versions because I am still using windows 7.
Re: shadow catcher
Posted: Fri Sep 01, 2023 11:43 am
modhob wrote: Thu Aug 31, 2023 9:48 pm ...I simply want the monkey shadow on it's own layer so I can change it's opacity or do whatever else with it.
Check "Holdout" on Suzanne's material output, that way you'll only get its shadow.
Re: shadow catcher
Posted: Fri Sep 01, 2023 5:43 pm
by modhob
The only place I see holdout is in the outliner, where you can hide from render etc. There is a holdout there, but I can't seem to select it for anything but a collection. So if I put suzanne in her own collection, I can toggle holdout on that collection. But it doesn't do anything to the render.
Are you talking about the same spot, or a node? Because I can't find holdout in the material output node. Just shadow catcher option.
Re: shadow catcher
Posted: Sat Sep 02, 2023 11:55 am
Ah, yeah, it's newer than what you've got, a 2.5 addition...
