Hello,
I'm not quite sure I even have the vocabulary to ask this question, but I'll try.
Is there are way to separate out normals based on geometry? This would allow applying a material based on the z slope of the normals, for example.
Attached is a screenshot of what it looks like in Cycles. Plugging this setup into a mix node allows mixing two materials based on the steepness of the area they are applied to.
Thank you!
Geometry nodes
Re: Geometry nodes
You can do this by calculating the dot product of the shading normal and the up vector.
(the power operation is just used here to enhance the contrast)
- Attachments
- slope.blend
- (1.12 MiB) Downloaded 151 times
