Hi all
I've seen that viewport shading (Material and Texture) options are not working, they're not showing the applied image texture to the node.
Windows build.
Regards.
Viewport shading not working as expected
Re: Viewport shading not working as expected
Can you describe more closely what is happening and how it should look like?
Maybe with screenshots, or compare to Cycles?
I guess you mean that you plug a diffuse texture in a LuxCore node tree and it does not show up in the OpenGL viewport?
Yes, exactly. Thanks for the answer.
Also the material viewport seems not very useful.
All of these are areas I have not touched at all yet.
I created an issue for later: https://github.com/LuxCoreRender/BlendLuxCore/issues/38
