Page 3 of 3
Re: LuxCoreRender v2.0rc1 released
Posted: Sun Apr 29, 2018 6:02 am
kintuX wrote: Sat Apr 28, 2018 11:06 pm - if Material is created directly by using Node Tree Presets instead of standard procedure (via New and then selecting from presets), material isn't shown in the Render Preview.
It happens without using node tree presets, too.
However, I already fixed this bug (after RC1, so you have to wait for RC2 or the final release to get the fix): https://github.com/LuxCoreRender/BlendL ... issues/142
kintuX wrote: Sat Apr 28, 2018 11:06 pm Seems i still got an issue with particles disappearing and duplicating curve Profile (observed in Data-Blocks Mesh menu). Maybe some corner case or old scene issue. Will make new/fresh one and report back.
Ok, I'll check it when I get the test scenes.
Posted: Sun Apr 29, 2018 7:21 am
kintuX wrote: Fri Apr 27, 2018 10:45 am Another strange thing is, i had rendered particles just fine yesterday...
Now: [Duplicator "Start"] Reference to an undefined NamedObject name: 365276232
I fixed this bug.
It was yet another regression caused by my introduction of the node cache. I should not do extensive refactoring a few weeks before release... :oops:
Posted: Sun Apr 29, 2018 10:50 am
by kintuX
B.Y.O.B. wrote: Sun Apr 29, 2018 6:02 am
Was testing latest (fixed) scripts ;) It now works fine, even if starting with presets.
Ok, so this is only happening with Curve objects: ie. BezierCircle & a Curve for Profile > Creates extra Meshes.
Happens every time when LuxCore2 Render Preview or Render is started and adds to the existing meshes.
Such behavior is not observed, if Cycles is used.
1. Start either Preview (shift+z) or Render (f12).
2. Observe in Outliner: Orphan Data > Meshes
(sorry for the small size preview and closed tree - beginner's mistakes, i hope you can see the issue)
CurveObjectTest.zip
(99.38 KiB) Downloaded 343 times
Posted: Sun Apr 29, 2018 11:03 am
Thanks for the report, fixed.
By the way, consider creating a github account so you can directly create github issues, it's much easier to keep track of those than of forum posts.
Posted: Sun Apr 29, 2018 12:31 pm
by kintuX
B.Y.O.B. wrote: Sun Apr 29, 2018 11:03 am Thanks for the report, fixed.
Fix confirmed.
