Hi, guys.
Is it possible to use Backbody Temperature with lights? Not a meshlight object.
Thanks in advance.
Backbody Temperature and lights
- Leandro Oliveira
- Contact:
- FarbigeWelt
- Contact:
Re: Backbody Temperature and lights
If not implemented in 2.5 alpha, I guess not. It has been discussed several times.Leandro Oliveira wrote: Sun Aug 30, 2020 10:55 pm Hi, guys.
Thanks in advance.
A triangle mesh with emission equals one area light.
A ditto triangle at the first‘s backside gets closer to a point light with two light sources. To simulate a point light the triangles‘ surface should be tiny.
Maybe you have it like me and artistic power setting sound rather mystic, then switch and you are able to choose lux, lumen or candela.
I like lumen because this fits good to LED package information and size of the light does not matter.
MacBook Air with M1
MacBook Air with M1
- Leandro Oliveira
- Contact:
Thank you, FarbigeWelt. I´ll make some tests about relationship between Light and Meshlight intensities.
- FarbigeWelt
- Contact:
You might be interested in my post here: viewtopic.php?f=4&t=2528&p=25075#p25075, especially my dot-blend-file.Leandro Oliveira wrote: Tue Sep 01, 2020 10:27 pm Thank you, FarbigeWelt. I´ll make some tests about relationship between Light and Meshlight intensities.
MacBook Air with M1
MacBook Air with M1
- Leandro Oliveira
- Contact:
Thank you, man! I´ll take a look.
