I can confirm the same behaviour described by gecko (Windows 10 v1809, Blender 2.90, LuxCore 2.5 alpha as of commit 9a0caab from 2 days ago).
It happens with all binary exports, either with Blender language set to "English" or to "Automatic".
Also modifying decimal and thousand separator in Windows control panel does not change the behaviour (I have Italian settings in Windows, but I manually set decimal separator to point and thousand separator to comma - the standard Italian setting is problematic for me with some other software. Both settings show the problem).
The error messages look identical to those described in this old issue (which was Linux-specific by the way):
https://github.com/LuxCoreRender/LuxCore/issues/80
The problem is also present when using Blender 2.83.5, while exporting with Blender 2.82 seems to solve it (same identical BlendLuxCore version in all Blender versions).
More specifically, when using the bcf exported from Blender 2.82, the render process starts without problems. At the moment of clicking "Finish job" on PyLuxCoreTool NetConsole, this error is triggered (which seems to me unrelated to the one in this thread):
[RenderFarmNodeThread-192.168.56.1:18018][2020-09-08 10:44:12,672] Sending seed: 1
[RenderFarmNodeThread-192.168.56.1:18018][2020-09-08 10:44:12,673] Waiting for node rendering start
[RenderFarmNodeThread-192.168.56.1:18018][2020-09-08 10:44:12,957] Node rendering started
[RenderFarmNodeThread-192.168.56.1:18018][2020-09-08 10:44:12,960] Node rendering statistics: [Elapsed time: 0sec][Samples 0][Avg. samples/sec 3.75M on 0.0K tris]
[RenderFarmNodeThread-192.168.56.1:18018][2020-09-08 10:44:22,967] Node rendering statistics: [Elapsed time: 10sec][Samples 17][Avg. samples/sec 3.58M on 0.0K tris]
[MainThread][2020-09-08 10:44:25,499] Stop current job
[MainThread][2020-09-08 10:44:25,500] -------------------------------------------------------
[MainThread][2020-09-08 10:44:25,500] Job stopped: C:/Dati/Various/Personal/Graphics/Work/LuxCoreRender/tests/pyluxcoretool_2.82_LuxCore/00001.bcf
[FilmMergeThread][2020-09-08 10:44:25,500] Film merge thread done
[MainThread][2020-09-08 10:44:25,501] Waiting for ending of: RenderFarmNodeThread-192.168.56.1:18018
[RenderFarmNodeThread-192.168.56.1:18018][2020-09-08 10:44:25,501] Receiving file: C:/Dati/Various/Personal/Graphics/Work/LuxCoreRender/tests/pyluxcoretool_2.82_LuxCore/00001-netrendering/RenderFarmNodeThread-192.168.56.1_18018-1.flm
[RenderFarmNodeThread-192.168.56.1:18018][2020-09-08 10:44:28,165] Transfered 17.17 Mbytes in 00:00:00 (153.20 Mbytes/sec)
[RenderFarmNodeThread-192.168.56.1:18018][2020-09-08 10:44:28,170] Node rendering statistics: [Elapsed time: 15sec][Samples 25][Avg. samples/sec 3.42M on 0.0K tris]
[RenderFarmNodeThread-192.168.56.1:18018][2020-09-08 10:44:28,170] Waiting for node rendering stop
[RenderFarmNodeThread-192.168.56.1:18018][2020-09-08 10:44:28,173] Node thread done
[MainThread][2020-09-08 10:44:28,174] No previous film to load
[MainThread][2020-09-08 10:44:28,174] Number of films to merge: 1
[MainThread][2020-09-08 10:44:28,174] Merging film: RenderFarmNodeThread-192.168.56.1:18018 (C:/Dati/Various/Personal/Graphics/Work/LuxCoreRender/tests/pyluxcoretool_2.82_LuxCore/00001-netrendering/RenderFarmNodeThread-192.168.56.1_18018-1.flm)
File "C:\Users\xxx\AppData\Local\Temp\_MEI157202\pyluxcoretools.zip\pyluxcoretools\pyluxcorenetconsole\ui.py", line 402, in clickedFinishJob
File "C:\Users\xxx\AppData\Local\Temp\_MEI157202\pyluxcoretools.zip\pyluxcoretools\renderfarm\renderfarm.py", line 154, in StopCurrentJob
File "C:\Users\xxx\AppData\Local\Temp\_MEI157202\pyluxcoretools.zip\pyluxcoretools\renderfarm\renderfarmjobsingleimage.py", line 300, in Stop
File "C:\Users\xxx\AppData\Local\Temp\_MEI157202\pyluxcoretools.zip\pyluxcoretools\renderfarm\renderfarmfilmmerger.py", line 101, in MergeAllFilms
RuntimeError: unregistered class
Edit: attached you can find the two bcf generated with Blender 2.82 and 2.90.
