Another old scene rendered with dispersion.
Just a test render with small resolution for now.
Fire Caustics
Fire Caustics
- Attachments
- fire_caustics.blend
- (164.12 KiB) Downloaded 380 times
Re: Fire Caustics
so beautifull so LUX !
Re: Fire Caustics
I did a test with your blend here are the result :
Bidir/metro :
Path/metro:
Gimp Mixed:
Why Bidir render don't show reflection on the glass cylinder
Bidir/metro :
Path/metro:
Gimp Mixed:
Re: Fire Caustics
Probably because the caustics are so bright that the auto tonemapper darkens the image.
Re: Fire Caustics
Especially if you are using the old glass code
Re: Fire Caustics
This gorgeous thing needed to be animated:
Re: Fire Caustics
Wow, thanks! Mesmerizing.
It even loops nearly perfectly, maybe one frame at the beginning or end is doubled (or it's my player that causes a slight pause).
