Unified executable (for CPU-only, OpenCL and CUDA)
Post by Dade » Thu May 21, 2020 3:27 pm
Introduction
The aim of this project is to have an unified executable capable to work on any platform supporting: CPU-only, OpenCL and CUDA. This task was triggered by the problem that you can not directly use CUDA in a Blender add-on on Linux (i.e. calling cuInit() crashes Blender) but, at the end it offers many advantages.
Advantages
There has many advantages:
- CUDA works with Blender and Linux;
- a single executable instead of 3 different one;
- you can compile the LuxCore sources without having to use OpenCL or CUDA SDK;
- it may be possible to extend the same approach to Optix in the future (avoiding to have 4 different executable !);
Testing
I have done the very first test of runtime loading of CUDA on the "cuda_ocl_wranglers" branch, @Acasta69 and @u3dreal can you check if CUDA still works on Windows and MacOS.
If does I can go on, I have to change a not trivial amount of stuff because having/not having CUDA and OpenCL will become a run-time condition, not more compilation time #ifdef.
My first test has solved the problem of running CUDA on Linux with Blender (i.e. no more crash).
acasta69
Re: Unified executable (for CPU-only, OpenCL and CUDA)
Post by acasta69 » Thu May 21, 2020 5:15 pm
Do you mean this should work even if compiled with OpenCL "disabled"?
There is a problem, though:
https://dev.azure.com/LuxCoreRender/Lux ... ew=results
These errors happen with no-ocl compilation after your fix for Apple texture mapping.
I don't really understand: shouldn't "cl" files be ignored in that case?
Compiling with Cuda "enabled" is working as usual.
Post by Dade » Thu May 21, 2020 5:52 pm
Not for the moment, for the first test, use OpenCL and CUDA enabled.
I will check.
u3dreal
Post by u3dreal » Thu May 21, 2020 6:00 pm
All works fine here .. There was even a driver update a week ago. :)
portfolio http://q3de.com/
MB Pro i7 2.3Ghz, IrisPro 1.5GB, GTX750m 2GB - High Sierra
Xeon X5650@4Ghz, 2x GTX 770 Phantom - High Sierra, Windows 10, Ubuntu 18.04
acasta69
Post by acasta69 » Thu May 21, 2020 6:53 pm
Everything's ok with this.
Post by Dade » Thu May 21, 2020 8:30 pm
Ok, I will continue and extend the dynamic loading of libraries to OpenCL.
Post by Dade » Wed May 27, 2020 11:14 am
Efff, things are never simply. I had to port all OpenCL host code from C++ bindings to plain C in order to get the OpenCL Wrangler to work. A lot of work and probably new bugs.
So now:
- you can compile the LuxCore sources without having to use OpenCL or CUDA SDK or OpenCL C++ bindings;
The work should be now complete, @Acasta69 and @u3dreal can you check it works on Windows and MacOS (stand alone and inside Blender) ?
acasta69
Post by acasta69 » Wed May 27, 2020 1:56 pm
Quick test on Windows (LuxcoreUI only): CUDA ok, OpenCL crashes while compiling kernels:
I cannot investigate further at the moment, will try later.
Indeed compilation works with OpenCL disabled flag.
However, we still need to distribute the NVRTC libraries, which are not part of the Nvidia drivers.
Those who compile their own executables will need the CUDA SDK. Or we could include the libs in the binary dependencies.
