LuxCoreRender v2.3beta2 released
Posted: Sun Feb 16, 2020 11:53 pm
Downloads:
Standalone: https://github.com/LuxCoreRender/LuxCor ... _v2.3beta2
Blender Addon: https://github.com/LuxCoreRender/BlendL ... _v2.3beta2
Changelog:
https://wiki.luxcorerender.org/LuxCoreR ... Notes_v2.3
LuxCore
New Features since Beta1
Old scenes created with v2.2 will need to be updated manually in the areas listed below to make them look the same in v2.3:
Changelog:
LuxCore
- Improved light map sampling in BAKECPU
- Added the support for transparencies and shadowcatcher to BAKECPU
- Fixed and optimized the execution on CPU with high thread count (24+)
- BAKECPU now correctly includes the dot product of shading normal and light direction in light maps
- Fixed the generation of material/object/volume default random ID (issue #296)
- Fixed bump mapping when using a transformation with negative scale on Z (issue #300)
- BlendLuxCore can now read some basic Cycles world and light settings. For more info see https://github.com/LuxCoreRender/BlendL ... issues/272
- Added option to normalize distant light (enabled by default)
- Objects that are completely invisible in Cycles (via ray visibility flags) are not exported by LuxCore anymore
- Allow to set light tracing partition even with OpenCL engine (so it's possible to use the CPU not only for light tracing)
- Added a button that allows to create a light object from an HDRI world (for free transformation)
- Fixed view layer override material not working
- Fixed instancer sometimes visible in final render despite disabled visibility
- Fixed packed image temp files not being closed before removal
- The ImagePipeline tonemapper default settings were changed: auto brightness is now disabled by default (was enabled), gain is now 1.0 by default (was 0.5)
- Lights now have two modes for choosing the brightness: "artistic" and "power". Default is now "artistic". This means that the light settings of old scenes have to be changed manually to make them look identical to v2.2.
- It is now no longer possible to tint the sun and the sky color.
- Sun lights in "distant" mode are now normalized by default. To make old scenes appear the same, disable the "Normalize" option in the light settings
- Camera clipping is now enabled by default. When loading old scenes, you'll have to disable it to get the same behaviour (although the difference is probably not visible in most scenes)
- The blackbody texture is now normalized by default. For scenes created in older versions, disable the normalize option to get the same result
