LuxCoreRender v2.3beta1 released
Post by Dade » Tue Jan 28, 2020 3:25 pm
Downloads:
Standalone: https://github.com/LuxCoreRender/LuxCor ... _v2.3beta1
Blender Addon: https://github.com/LuxCoreRender/BlendL ... _v2.3beta1
Changelog:
https://wiki.luxcorerender.org/LuxCoreR ... Notes_v2.3
LuxCore
New Features since v2.2
  • LuxCoreUI now shows eye and light pass counters if light tracing is enabled
  • FILESAVER now expands inline exported constant texture values
  • PhotonGI caustic scene re-factored to work with Vertex Merging (i.e. SPPM in this case)
  • It is now possible to use light tracing for normal caustics and PhotonGI cache for SDS paths
  • Added the support for shadow rays transparency for path tracers (aka hybrid glass, issue #233)
  • Added the support for Basu and Owen's low discrepancy triangle light sampling (pull request #246)
  • Added an option to normalize BlackBody texture output
  • Pointiness shape is now able to handle duplicate/similar vertices like if they were the same
  • Added the support for Subdivison shape (base don OpenSubdiv)
  • Added the support for Displacement shape
  • Added the support for vector displacement to Displacement shape
  • New image pipeline plugin: White balance
  • Using/Not using bump/normal mapping doesn't require OpenCL compilation anymore (removed PARAM_HAS_BUMPMAPS conditional OpenCL compilation)
  • Large rework of internal light interface. Fixed several instance/motion blur and lights related problems. Triangle light motion blur now works as expected in OpenCL.
  • Large rework of internal mesh interface. Improved the performance of instanced and motion blur meshes.
  • Changed object and material ID for background to 0 (from 0xffffffff)
  • Added the support for screen space subdivision limit to SubdivShape
  • Using/Not using any type of transparency doesn't require OpenCL compilation anymore (removed PARAM_HAS_PASSTHROUGH conditional OpenCL compilation)
  • Added an Harlequin shape (mostly to debug meshes)
  • Added a Simplify shape (to decimate the number of triangles in a mesh with the smaller possible error)
  • Reduced the default number of OpenCL threads from 512k to 256k (to save about 150MB of GPU RAM at 1-2% performance cost)
  • Changing max. path and/or Russian Roulette parameters doesn't require OpenCL compilation anymore (removed PARAM_MAX_PATH_DEPTH, PARAM_MAX_PATH_DEPTH_DIFFUSE, PARAM_MAX_PATH_DEPTH_GLOSSY, PARAM_MAX_PATH_DEPTH_SPECULAR, PARAM_RR_DEPTH and PARAM_RR_CAPPARAM_HAS_BUMPMAPS conditional OpenCL compilation)
  • Added the support the definition of meshes with multiple UVs, Colors and Alphas (issue #134)
  • Added the BAKECPU engine (LuxCore API only)
  • Added the glTF v2.0 FILESAVER support (LuxCore API only)
  • Changing hybrid backward/forward path tracing settings doesn't require OpenCL compilation anymore (removed PARAM_HYBRID_BACKFORWARD and PARAM_HYBRID_BACKFORWARD_GLOSSINESSTHRESHOLD conditional OpenCL compilation)
  • Changing PhotonGI settings doesn't require OpenCL compilation anymore (removed PARAM_PGIC_ENABLED, PARAM_PGIC_INDIRECT_ENABLED, PARAM_PGIC_CAUSTIC_ENABLED, etc.)
  • Changing force black background flag doesn't require OpenCL compilation anymore (removed PARAM_FORCE_BLACK_BACKGROUND)
  • Changing variance clamping settings doesn't require OpenCL compilation anymore (removed PARAM_SQRT_VARIANCE_CLAMP_MAX_VALUE)
  • Changing LIGHT_WORLD_RADIUS_SCALE doesn't require OpenCL compilation anymore (removed PARAM_RADIUS)
  • Removed HitPoint struct variable size related to PARAM_ENABLE_TEX_HITPOINTCOLOR, PARAM_ENABLE_TEX_HITPOINTGREY, PARAM_ENABLE_TEX_HITPOINTALPHA and PARAM_TRIANGLE_LIGHT_HAS_VERTEX_COLOR to avoid OpenCL re-compilation
  • Enabling/disabling volumes doesn't require OpenCL compilation anymore (removed PARAM_HAS_VOLUMES and SCENE_DEFAULT_VOLUME_INDEX)
  • Added the support for triplanar mapping
  • Enabling/disabling camera clipping and/or OculusRift barrel doesn't require OpenCL compilation anymore (removed PARAM_CAMERA_ENABLE_CLIPPING_PLANE and PARAM_CAMERA_ENABLE_OCULUSRIFT_BARREL)
  • Changing any pixel filter related parameter doesn't require OpenCL compilation anymore (removed all PARAM_IMAGE_FILTER_*)
  • Disney material now accepts values > 1.0 for sheen parameter
  • Changing camera type doesn't require OpenCL compilation anymore (removed PARAM_CAMERA_TYPE)
  • Changing any image map related settings doesn't require OpenCL compilation anymore (removed all PARAM_HAS_IMAGEMAPS_*)
  • Added the support for UV-less bump mapping with triplanar mapping
  • Changing the number of light groups used doesn't require OpenCL compilation anymore (removed PARAM_FILM_RADIANCE_GROUP_*)
  • Reduced (again) the default number of OpenCL threads from 256k to 128k
  • Added the support for .normalizebycolor emission property
  • Using a GPU memory block larger than CL_DEVICE_MAX_MEM_ALLOC_SIZE now triggers only a warning. Some driver/hardware (i.e. NVIDIA) is able to allocate larger blocks.
  • Enabling/disabling BCD denoiser doesn't require OpenCL compilation anymore (removed PARAM_FILM_DENOISER)
  • Changing RTPATHOCL rendering parameters doesn't require OpenCL compilation anymore (removed PARAM_RTPATHOCL_*)
  • Rework of OpenCL samplers code to not require OpenCL compilation anymore when changing sampler (removed PARAM_SAMPLER_*)
  • Changing AOVs used doesn't require OpenCL compilation anymore (removed PARAM_FILM_CHANNELS_*)
  • Adding/Removing a new light source type doesn't require OpenCL compilation anymore (removed PARAM_HAS_*LIGHT)
Fixed Bugs since v2.2
  • Fixed triangle lights back face emission when using an IES or image map profile
  • Fixed OpenCL code for rotate triangle light when using IES or image map profile (BlendLuxCore iusse #310)
  • Fixed light tracing when using orthographic camera
  • Fixed a light intensity problem with OpenCL rendering when using a mix of materials with emission
  • Fixed the support for wrap mode in image maps loaded from files
  • Fixed a brightness problem when rendering large images with Metropolis sampler
  • Fixed a brightness problem when rendering caustics with PhotonGI caustic cache
  • Fixed a bug in Mix material OpenCL code when mixing transparent and not transparent materials
  • Fixed a crash when rendering an empty scene with OpenCL and EnvLightVisibilityCache
  • Fixed a problem with mesh light sources when deleting an object with LuxCore API (issue #290)
  • Fixed a bug when evaluating complex tree of bump mapping nodes (issue #198)
Blender Addon
  • OpenVDB node
  • Support for new shadow color feature
  • Support for new white balance image pipeline plugin
  • Area lights now have UV coordinates
  • Image sequence support
  • Triplanar mapping node (+ triplanar bump node)
  • Rework of caustic cache settings
  • Only disable imgpipeline plugins in viewport because of denoiser when necessary (only for contour lines and color aberration)
  • Support for blackbody normalize option
  • New "exclude from render" flag for objects, to make it possible to have them visible in other render engines but invisible in LuxCore
  • Support for LuxCore shape pipeline and new shape modifiers: OpenSubDiv, Displacement, Vector Displacement, Simplify
  • Sun lights are now by default invisible to indirect specular rays when using the Path engine, because these paths would only generate fireflies anyway
  • New TimeInfo node
  • Allow values > 1 in disney sheen parameter
  • Accelerated export of instances and particles (in a scene with 100,000 particles: from 33 seconds in v2.2 to 1.3 seconds total export time in v2.3)
  • Improved status messages in the UI during export of complex scenes
  • Added camera invisible support for hair
  • Hair on instances is now duplicated correctly
  • Float node sockets now show 3 instead of 2 decimal places
  • Make it possible to enable/disable PhotonGI in materials even if PhotonGI is disabled globally
  • Support for environment light cache persistent file
  • Support for direct light cache persistent file
  • Fixed bugs in smoke export
  • Show camera background image panel
  • Fixed film refresh not happening at the promised time because it was waiting for the next statistic update
  • Fixed instancer being shown in final render even if disabled
  • Fixed smoke export to match cycles render by translate the grid by 1/4*cell_size
  • Fixed light emission when Power or Efficacy = 0
  • Support for multiple UV maps and multiple Vertex color channels
  • Fix UV offset being off by 1 in some node setups due to a correction factor being applied twice
Changes that break backwards-compatibility
Old scenes created with v2.2 will need to be updated manually in the areas listed below to make them look the same in v2.3:
  • The ImagePipeline tonemapper default settings were changed: auto brightness is now disabled by default (was enabled), gain is now 1.0 by default (was 0.5)
  • Lights now have two modes for choosing the brightness: "artistic" and "power". Default is now "artistic". This means that the light settings of old scenes have to be changed manually to make them look identical to v2.2.
  • It is now no longer possible to tint the sun and the sky color.
zuljin3d
Re: LuxCoreRender v2.3beta1 released
Post by zuljin3d » Tue Jan 28, 2020 3:46 pm
:o
Many thanks to all the developers.
Taka
Post by Taka » Tue Jan 28, 2020 4:18 pm
Thank you so much for your hard work!
juangea
Post by juangea » Tue Jan 28, 2020 5:52 pm
Great news! Thank you!
Post by Racleborg » Tue Jan 28, 2020 6:14 pm
Wow! Thank you. :D
Post by marcatore » Wed Jan 29, 2020 8:51 am
Really good!
Thank you very much
Darth Blender
Post by Darth Blender » Wed Jan 29, 2020 3:31 pm
Sorry for the question, but... what are the differences between the dailybuilt and this one version?
Post by Dade » Wed Jan 29, 2020 3:49 pm
This a daily build that is supposed to be more stable. In general, beta1 is the point where we stop adding new features and we only do bugs fixing until the release of final v2.3.
Now on, the development of new features is done on Git branches (for instance, the ongoing for https://github.com/LuxCoreRender/LuxCor ... xture_eval ) and the will be part of the next release (i.e. v2.4).
