More than one question (Hybrid Back/Forward path tracing)
Re: More than one question (Hybrid Back/Forward path tracing)
Post by Dade » Wed Jan 29, 2020 11:38 am
juangea wrote:
Wed Jan 29, 2020 10:40 am
Does persistent cache takes into account time?
Only for the motion blur time of the current frame (see below).
I mean, can it use the persistent information to increase the data for frame 2 using the data from frame 1? or can it interpolate if we calculate persistent data for frame 1,5 and 10, can it interpolate and use persistent data to extrapolate or accelerate render for frames 2,3,4,6,7,8,9?
LuxCore has no information at all about animation, it sees only the current frame to render. The only time related information is about motion blur. So the only time related information it has is about the animation happening inside the frame it is currently rendering.
I would like to know how it works for animation :)
Persistent caches should be used with static environments: for instance a camera fly trough is the typical application and they are very effective because you amortize the cache pre-processing cost over all the frames you have to render.
juangea
Post by juangea » Wed Jan 29, 2020 12:48 pm
ok, thanks for the clarification :)
May be good to have the cache, even if it's not persistent, to take into account the previous frame to avoid probelms or is it stable as it is?
(just curiosity)
tokiop
Post by tokiop » Wed Jan 29, 2020 4:17 pm
Sharlybg wrote:
Wed Jan 29, 2020 8:41 am
P.S. and I must admit I don't see any flickering in this one: viewtopic.php?f=4&t=1688&start=10#p19307
same here.
but it is probably this one :
https://streamable.com/d30uq
But maybe this was already fixed i haven't really follow this thread well.
Also, in the streamable one the light/sun is animated, so persisting cache might be discarded / irrelevant ?
Post by Dade » Wed Jan 29, 2020 5:18 pm
Yes, I explained in the original thread why using a persistent cache with with animated "things" can lead to problems.
