Compile on MacOS
Re: Compile on MacOS
Post by Dade » Tue Dec 03, 2019 11:09 pm
u3dreal wrote:
Tue Dec 03, 2019 10:51 pm
I'll compile it manually to see whats is missing ... freetype is installed via brew
But is it in the list of linked libraries (if it is not directly included in OpenImageIO) ?
u3dreal
Post by u3dreal » Tue Dec 03, 2019 11:28 pm
freetype is set to find silently .. :) well see i just compile oiio
u3dreal
Post by u3dreal » Tue Dec 03, 2019 11:37 pm
oiio compiled fine with all the flags from the "build_deps" script ... finding freetype of course during configure ... now let's seee :shock:
u3dreal
Post by u3dreal » Tue Dec 03, 2019 11:42 pm
This drives me crazy ... another thing missing from oiio looks like dlib ... installed it let's see ..
edit it's libgif :(
why is it disabled in the build_deps script ? :shock:
Undefined symbols for architecture x86_64:
  "_DGifCloseFile", referenced from:
      OpenImageIO_v1_8::GIFInput::seek
u3dreal
Post by u3dreal » Wed Dec 04, 2019 1:03 pm
OK problem was that osx does not permit static linking of external sources mainly into oiio.
Building dynamicaly works. :D
Running 2.3git ;)
I guess for the release we'll have to copy some more .dylibs
u3dreal
Post by u3dreal » Wed Dec 04, 2019 11:52 pm
OK i got something running here . Could someone plz point me to the buildphase where the binaries get patch with @rpath ?
I want to add OpenImageIO and OpenImageDenoiser too. fixing them afterwards with install_name_tool is horrible ... or i don't know what i'm doing.
At least not very perdictable :) thanks is advance.
In fact pyluxcore.so and BlendLuxCore seems to work on my other mac where no homebrew is installed. denoise is a bit of a problem. Can't get it to work sp far.
Post by Dade » Thu Dec 05, 2019 12:50 am
Do you need to set the rpath of pyluxcore.so (https://github.com/LuxCoreRender/LuxCor ... eLists.txt) ? Or luxcoreui executable (https://github.com/LuxCoreRender/LuxCor ... eLists.txt) ? Or ?
Post by Dade » Thu Dec 05, 2019 12:51 am
The binaries are directly from Intel (https://github.com/OpenImageDenoise/oidn/releases), it is strange, does the denoise command work ?
u3dreal
Post by u3dreal » Thu Dec 05, 2019 1:03 am
It works on the build machine but not the the other mac. But when i manually do
install_name_tool -change bal/bla/bla/libOpenImageDenoiser.0.dylib @rpath/libOpenImageDenoiser.0.dylib denoise
denoise does not find the lib not even on the build mac.
I found the if Apple section ... how might the iodn lib be namend ?? ahh OIDN_LIBRARY ... and ?? libOpenImageIO ? OIIO_LIBRARY ?
Sorry this is all the so new but i thing i got the symbols thing.
u3dreal
Post by u3dreal » Thu Dec 05, 2019 1:58 am
OK now i'm confused ... does pyluxcore need to be linked against OpenImageDenoise ??? I guess not since it works without :?
