Light Tracing Pass
PetrT
Light Tracing Pass
Post by PetrT » Tue Sep 10, 2019 11:11 am
Hi
Interested. Can be rendered Light Tracing Pass -?
Re: Light Tracing Pass
Post by Dade » Tue Sep 10, 2019 11:16 am
It is possible with a trick: set the partition between eye and light passes to 0.0 and render with PATHCPU. The result will be the rendering of only light passes (because the eye passes are set to 0%).
For instance:
PetrT
Post by PetrT » Tue Sep 10, 2019 11:20 am
Can be done it on OpenCl-?
Post by Dade » Tue Sep 10, 2019 11:24 am
Light tracing is only done on the CPU even when using OpenCL rendering. Rendering only caustics is a very specific and very fast task, CPUs are good enough.
PetrT
Post by PetrT » Tue Sep 10, 2019 11:27 am
thank you very much for your answer
