pathOCL turning singlesided meshes transparent
lacilaci
Post by lacilaci » Mon Sep 09, 2019 10:31 am
This is something I have hard time replicating in isolated scenes but several times already I had this problem where planar single sided meshes would disappear when rendered with pathOCL
pathOCL:
pathCPU:
mesh:
mesh has no problems and normals pointing the right way, in fact in past I've experienced this problem even with basic plane... I don't know yet how to replicate the problem..
lacilaci
Re: pathOCL turning singlesided meshes transparent
Post by lacilaci » Mon Sep 09, 2019 10:53 am
it's just so weird..
look at tables on the lower level, you can see their white tabletops even from distance...
but the ones on the top level suddenly have their top disappearing...
these are all instances of the same object
lacilaci
Post by lacilaci » Mon Sep 09, 2019 11:05 am
aaand, if I move the very same broken table from top level next to one on the lower level.. It's tabletop appears again normally.... I'm so confused
Post by B.Y.O.B. » Mon Sep 09, 2019 2:28 pm
Does the table have some weird transformation on it, like negative scale, or is it scaled up/down a lot?
Post by kintuX » Mon Sep 09, 2019 2:35 pm
I think it's precision issue, starting with huge plane/boundary to satisfy the need for horizon... can you remove the big stuff from your scene and check again?
lacilaci
Post by lacilaci » Mon Sep 09, 2019 2:42 pm
I tried reseting transforms it still shows...
But I don't understand why some copies show normally (these are all a single linked collection)
But it's not related to linking since it happened to me once on multiple copies of a single plane in single scene where all planes went invisible for render until I added thickness...
lacilaci
Post by lacilaci » Mon Sep 09, 2019 2:43 pm
There is no ocean mesh anymore (it's disabled from rendering) what you see is just ground color set in sky shader
Post by Dade » Mon Sep 09, 2019 2:55 pm
You should post a test scene.
lacilaci
Post by lacilaci » Mon Sep 09, 2019 3:02 pm
I can make copies around the bad table and they're ok, but the moment I put a table in the spot as the bad one, it becomes also bad :D
Doesn't even need to be exactly at the same spot....
lacilaci
Post by lacilaci » Mon Sep 09, 2019 3:04 pm
Yes I should, but I cannot replicate this error in an isolated scene... It only happens here... I have an idea how to replicate, will try tomorrow..
