lighttracing disables reflections on disney
lacilaci
Post by lacilaci » Thu Aug 15, 2019 11:25 am
when using disney material and lighttracing material reflections gets disabled when using glossiness bellow 0.05
to best illustrate the problem I've put metallic slider on disney to max but the problem is present even without it
disney at glossiness 0.05
disney at glossiness on anything bellow 0.05
this is not happening on glossy2 and metal material which work the same even when using lighttracing
the problem is not present when lighttracing is disabled
Re: lighttracing disables reflections on disney
Post by kintuX » Thu Aug 15, 2019 11:07 pm
I think that what you're observing, are light rays that don't get to the eye. And if IIRC, it's already mentioned couple of times.
Take notes & simply don't go under/over the threshold. ;)
lacilaci
Post by lacilaci » Fri Aug 16, 2019 3:59 am
Not sure what you mean, and also why the different behavior between disney and others...
Post by Dade » Sun Aug 18, 2019 3:31 pm
