Camera Volume test
wasd
Camera Volume test
Post by wasd » Thu Jun 13, 2019 3:34 am
Camera volume set to World Volume (or autodetect):
Camera volume set to ---:
Materials affected:
  • Glossy Translucent
  • Matte Translucent
  • Rough Glass
Materials not affected:
  • Glass
  • Architectural Glass
  • Null
volume_test-d.blend
(1.04 MiB) Downloaded 17 times
CPU Bidir (sometimes GPU Path) + Metropolis | Log Power | Core i5-4570
wasd
Re: Camera Volume test
Post by wasd » Sat Jun 15, 2019 8:01 am
@B.Y.O.B. Could you look into this, please?
Post by B.Y.O.B. » Sat Jun 15, 2019 8:29 am
I doubt that it is a bug in the addon. Apart from the material type, the scene properties are the same.
It is either a bug in LuxCore or a problem in the scene setup.
Piita
Supporting Users
Post by Piita » Sun Jun 16, 2019 5:08 am
I can't reproduce it on my end. Using world_volume and autodetect both produce the same as cavo-1.jpg. I don't have the option to select the --- volume. Could this be an old bug that has recently been fixed? I use blendluxcore 2.2 beta 1 and luxcore 2.2 beta 2
Piitas.blog
Librem 5 - The privacy focused smart phone. It does not run Android or iOS that track you and send data about you to Google.
Post by B.Y.O.B. » Sun Jun 16, 2019 8:35 am
"---" is not an actual volume, it just means no volume, you get it when you press the "x" on the far right.
Piita
Supporting Users
Post by Piita » Sun Jun 16, 2019 10:52 am
Ah, yes, that was it. Now I get the same red cube too
Piitas.blog
